Old 08-04-2008, 01:20 PM   #1
67mater
67mater's Avatar
SM420 twin stick
anybody have pics of a twin stick on an SM420 transfer case? I have an idea but know there are some great fabricators on here. Any twin stick would be cool to see. How far between pivot and end? I'd like the pivot to be right at the floor hump level, so I can have a small boot opening and no movement there, but that means less leverage so I don't want it to be too ahrd to shift into gear. of course, it should take much to engage if properly setup. Also, how short can the shaft be and still get enough leverage? I may tack something up and see how small I can go and still easily engage. Anybody have an opinion on using bearings or just a greased up through bolt for the pivot?
Also, when I rebuilt my 420 I noticed that the detent balls on the shift rods are what keep you from doing 2-LO, anybody pulled that ball (perhaps with some other means of positively engaing the shifter in gear) to allow 2-LO? i ask b/c I have a 1 ton Eaton rear and a D44 and if I am pulling or hauling and want low gear I might not want to risk breaking my 1/2 ton 44.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 08-04-2008, 01:27 PM   #2
FormerMember
Re: SM420 twin stick
SM420 is a transmission...
Do you mean a NP205?
FormerMember is offline   Reply With Quote
Old 08-04-2008, 01:28 PM   #3
FormerMember
There are what I run:
http://northwestfab.com/Shifters.html
I run a ground shift rail. You still need the ball bearings on the shift rod, but can give them more room.
http://ivanribic.clubfte.com/page2.html
Old 08-04-2008, 01:49 PM   #4
67mater
67mater's Avatar
sorry Timken 221 is what I was thinking
1967 K10
1967 Camaro
Old 08-04-2008, 03:34 PM   #5
Yukon Jack
Yukon Jack's Avatar
You might be able to find someone over at pirate4x4.com who has twinsticked a T221, but I've never heard of it being done.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
