Old 08-01-2008, 08:51 AM   #1
BowTieOgre
Tilt Column Signal Lever
I did a quick search and didnt find the exact info I needed. Ive got a tilt column out of an '80 that was shipped to me with the levers detached and Im wondering how to reattach the cruise/signal lever.
Kris
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 08-01-2008, 11:14 AM   #2
wedgemon
wedgemon's Avatar
Re: Tilt Column Signal Lever
With the wheel off. Remove the lock-plate. You'll want a lock plate tool. Worth the money to avoid the 2 screwdriver snap-ring drama. You'll see right where to attach the lever. Just remember to thread your cruise wire down thru the column and plug it in.
Re-assemble.
- Dave
I'm serious about the lock plate tool!!
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 08-01-2008, 11:22 AM   #3
BowTieOgre
Thanks for the info Dave.
Old 08-02-2008, 01:04 AM   #4
BowTieOgre
I picked up the tool at the store and had it fixed up in about 5 minutes.
Old 08-04-2008, 06:56 PM   #5
wedgemon
wedgemon's Avatar
Cool Re: Tilt Column Signal Lever
BTO -
That tool almost makes you WANT to work on the column!
Glad it was so easy.
- Dave
Founding Member:
Old 08-04-2008, 07:13 PM   #6
COMP
which one did you get ??
COMP is offline   Reply With Quote
Old 08-04-2008, 09:26 PM   #7
BowTieOgre
Im not sure of the brand but it was a lock plate removal tool from the local parts store...around $20.
Old 08-04-2008, 09:30 PM   #8
COMP
i was looking at one and it looked really cheap at HF ,,5 bucks
Old 08-05-2008, 09:39 AM   #9
BowTieOgre
That might be the way to go if you only plan to use it once...as with most things from HF. Im not saying dont shop at HF because I do it myself for piddly things.
Of course after I get the lever in and get the column back together I cant get my stock one out!!! The bolt just inside the engine side of the firewall connecting the int. shaft just will not come out! I got the nut off easy enough but the bolt just wont budge. The head is perfectly round so I tried tapping it out from the back with no luck and it only rotates like 15 degrees.
Old 08-06-2008, 03:59 PM   #10
87Bob
I have a column as well as I want to work on. Could you give more information on the tool? I have O'Reiley and Auto Zone in my area. Should they know what I'm looking for if I ask for a lock plate removal tool?
87Bob is offline   Reply With Quote
Old 08-06-2008, 04:20 PM   #11
COMP
i have 3 trucks alone to do
Old 08-06-2008, 04:32 PM   #12
87Bob
HF? What is HF?
Old 08-06-2008, 04:33 PM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
Buy one, you will use more than once in your life. Mine fits many different column threads and sizes.
Old 08-06-2008, 05:25 PM   #14
pcmcobra
pcmcobra's Avatar
HF = Harbor Freight (discount "chinese" made tools) good when your in a pinch!
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 08-06-2008, 05:51 PM   #15
andresco50
andresco50's Avatar
I made my own lock plate remover check this... and here's a forum for GM tilt steering removal....
http://www.buickperformance.com/tilt...lumnwobble.htm
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-06-2008, 05:57 PM   #16
COMP
link
Old 08-06-2008, 10:17 PM   #17
87Bob
Thanks! That is an awesome post for the column teardown and rebuild
