Old 02-08-2003, 12:06 PM   #1
Orence1
Orence1's Avatar
Ram Air Box
Have any of you guys thought about this set-up or seen it done on our trucks? Read a tech article that indicates a 25 hp gain over standard air cleaner because you are using cooler, more dense air. My question would be the best location on the core support for the vents that the hoses attach to.
Orence1 is offline   Reply With Quote
Old 02-08-2003, 02:22 PM   #2
Blue Beard
Blue Beard's Avatar
Saw one awhile back on ebay that someone had spliced a second unit on....nicely done......
I've thought about these as well........
Would be interested on info on this unit.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-08-2003, 02:57 PM   #3
Orence1
Orence1's Avatar
Bluebeard,
Check out this link:
http://www.ramairbox.com/
Old 02-08-2003, 08:25 PM   #4
Blue Beard
Blue Beard's Avatar
Orence1
Thanks for the link.....the kit link was kind of messed up......will contact them to get more info for trucks......
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 02-08-2003, 08:55 PM   #5
Orence1
Orence1's Avatar
Let us know what you find out.
Larry
Old 02-09-2003, 03:23 PM   #6
Blue Beard
Blue Beard's Avatar
Orence1
Here's the information on the Ram Air:
Would like to know if you have kits for the 67-72 Chevrolet Trucks
>available?
I suggest the
Full kit Part # F14x4@110kit
includes: 14x4@110, 14AL/DCover, AF4 air filter & 14AL/FBase
10' AL4 tubing, 4x HS64 hose clamp, 2x 4FLC fish-lock intake collar,
Stud & Nut, Seal & instruction pack.
is $208.45US incl S&H.
You may place your order over the phone with Visa, M/C or AmEx.
(905) 549-6135, 8AM to 5PM Monday to Friday.
Not bad since it includes shipping and handling to the US
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 02-09-2003, 08:22 PM   #7
Orence1
Orence1's Avatar
Got a chance to look at a 69 today with a 454 and a full radiator shroud. At this point I don't see where the hoses could outlet. With the battery tray there is just not a lot of room on the core support. Any thoughts? Also, thanks for doing the research.
Larry
Old 02-10-2003, 03:47 PM   #8
68racer
Yeah baby!
68racer's Avatar
I run a ram air box, they do work. My battery went out back a long time ago. I cut holes each side of the radiator. Still perfecting this part. On a 68 grille it's not so easy to line up. I have two ducts from an extractor hood for a domestic hob. They are the right transition from rectangle to round. I am going to mount these in the grille using a lower grille in the upper hole (without the lights), the air will then feed from the light holes.
11.37 @116
68racer is offline   Reply With Quote
Old 02-10-2003, 04:01 PM   #9
racedvl
racedvl's Avatar
This was posted quite some time ago. I'm pretty sure that the guy that owns this is still a board member.
racedvl is offline   Reply With Quote
Old 02-10-2003, 04:11 PM   #10
Project1970
14.1 @ 96MPH
Project1970's Avatar
I wouldn't want to lose the use of two of my headlights, but I would think it could be possible to run to oblong intakes in the grille...
My other idea involves building a cowl-induction box that sucks air in from the same place as the air conditioning intake, for that sleeper effect. The only possible problem with that would be water...still thinking that one over...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-10-2003, 04:27 PM   #11
72sbfs
Another good option is to use a cowl induction hood with the top of the cleaner sealed to the bottom of the hood. Just leave the back of the cowl hood opened. There is a low pressure area at the base of the windshield good for picking up cool air. Seems to me I read an article in a mag at one time that ram air only becomes functional at higher speeds. I will be using a cowl induction hood on my truck with the air cleaner sealed to the hood.
BTW that is a cool looking ram air box.
S
Size does matter, get a BB!
72sbfs is offline   Reply With Quote
Old 02-10-2003, 06:50 PM   #12
chaptr2
chaptr2's Avatar
That is my truck. I don't have that set up any more, but I remember all the details from it. I'm here if you have any questions.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 02-10-2003, 08:57 PM   #13
Reumster
L.E.D. Freak
Reumster's Avatar
Someone makes a Ram air hood for our trucks US Body Source I believe. Don't like them, but I want a Cowl Fiber hood, like to do the seal to cowl thing. But I like the ram air idea a little better. I think all it take is some wire relocation/rerouting, and a battery relocation.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 02-10-2003, 11:31 PM   #14
Gee_Emm
Does anyone think that setup on the red truck would work? Its a neat idea and all but I would think that the resistance on the air inside the corugated hose would cancel out any improvements the whole deal would make.
Gee_Emm is offline   Reply With Quote
Old 02-10-2003, 11:39 PM   #15
72ChevyCheyenne
72ChevyCheyenne's Avatar
Here is a pic of the Ram Air II Hood. This is what I am putting on my 72. I like the look.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 02-11-2003, 02:05 AM   #16
Orence1
Orence1's Avatar
Cool hood! What's the pricetag on one of those?
Old 02-11-2003, 03:37 AM   #17
Andy4639
Old member
Andy4639's Avatar
Cool Cold Air
This is my set up. I know it's for fuel injection, but it would work for carb engines too.
I bought some 4" black pvc from lowes, a 90 caddy air box, closed up the factory opening and cut a 4" hole into the bottom of it. The black pvc 90 with 2 screw coupling that I sawed off the threads and just used the flange to stick through the radiator support and hooked the 90 to then used the other couplinen in the air box and hooked to the other side of the 90. I have a late model alternater with the built in regulator so I drilled a 4" hole there.
I think it would work fine on a carb truck also. If I get time I will take it apart and take some pictures.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2003, 03:45 AM   #18
Hooter
My other Love
Hooter's Avatar
There is the equivilent to a ram air box on my Ford, doesnt seem to make a difference if i put the plastic duct back on or off
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-11-2003, 12:23 PM   #19
chaptr2
chaptr2's Avatar
Yes Gee_Umm that set up worked. At the time I had a naturally aspirated 383 with a Holly 650. As soon as I put the ram air on the engine would run out of fuel at the top end. I then put a 750 and never had a problem. Yes it works without a doubt. The only problem is you are not supposed to use it during cold weather because your carb could freeze. I remember when it got near freezing it was a little temperamental.
On the GMCs they have two holes in the outside part of the core support. I moved the outer high/low beams to the inside and put them in the center. I used Hella headlights to make up the difference for loss high beam light. I think the hole is around three inch hole and I just used adapters to make it fit with the five inch tubing. That setup would fit under a stock hood and use a five-inch air cleaner and a drop base.
Reumster is right about the wiring. I had to move the junction block near the battery, but never had to move the battery it self it would fit just fine. I just attached the wires that went to the junction block to the battery directly using my unused side posts on the battery. That way it cleaned up the side of the fender and made room for the tubes.
Check these links out.
Ram air 1 Link 2
