Old 08-07-2008, 03:25 PM   #1
stump
how to get gas out of tank
i got a free van from my work (blue berry raking) it is a 81 chevy somthing.. got a 5.0 in it.. it blew up last week and i got it for free.. he just put 70$ in gas in it.. how could i get it out? i dont want to wreck the tank really... thanks
stump is offline   Reply With Quote
Old 08-07-2008, 03:57 PM   #2
BowTieOgre
Re: how to get gas out of tank
When I bought the '78 van that I took the motor out of for my truck I opened the gas cap and pulled the supply line at the fuel pump up front, when I did that the suction from the gas that was in between the pump and the tank sucked the rest of the gas out of the tank.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 08-07-2008, 04:30 PM   #3
tobiahr
tobiahr's Avatar
I've done the same thing using a universal electric fuel pump and one of the cheap siphon pumps from harbor fright. just disconect the line from the mechanical fuel pump and attach flexable line to the hardline. the electric took about 15 mins to drain the tank from my blazer (25 gal tank)
tobiahr is offline   Reply With Quote
Old 08-07-2008, 05:02 PM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
I went the redneck way and put a CLEAR hose down into the tank. Suck on it (not when anyone else is around ) just enough to get passed the high point. Don't suck till u get gas, it doesn't taste to good I hear. Once you get passed the high point, drop the tube into a can and physics will do the rest.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-07-2008, 08:02 PM   #5
stump
haha i didnt know i could siphen it out.. gas is great what are you talking about?? iv swallowed some before when suckin it out of a snow sled haha
Old 08-07-2008, 09:00 PM   #6
hdflstf
hdflstf's Avatar
Take that long hose and cut a slit in it about 6 in from the end. The slit should be angled and across the hose. Angle it so that you can insert a compressed air blower attachment nozzle into the flow path pointing towards the exit end. Put an airhose fitting or some type of hollow metal fitting on the other end of the hose. When you hear the metal hit the bottom of the tank, you have enough hose in the tank. Fire up the compressed air through the slit and you siphon will be primed and flowing in about a second (or less).
No more mouth full of gas....
hdflstf is offline   Reply With Quote
Old 08-07-2008, 09:40 PM   #7
WarBeard
WarBeard's Avatar
Isn't it funny that normally we are happy about getting a free vehicle?
But now days its the gas in the tank of that free vehicle is the most valuable part
WarBeard is offline   Reply With Quote
Old 08-07-2008, 09:50 PM   #8
stump
haha.. im happy about the van to sence its worth 500 at the scrap yard.. i have a bunch of metal to fill the huge empty room behind the front seats
Old 08-07-2008, 10:35 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
shame there are no other good parts to put in your truck
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-08-2008, 09:33 AM   #10
BowTieOgre
Check the column in that van. If it is a tilt and it has the key on the dash you might be able to sell it to one of the 67-72 guys that wants to do a column conversion. Also, if it has intermittent wipers on the dash you may be able to sell that as well. The mounting tabs are different than our trucks but I think the delay wiring is the same.
Old 08-09-2008, 02:32 AM   #11
asphaltburner
asphaltburner's Avatar
Yo! stump!
Once you get the hang of it, it's easy and no mouth full of fuel! I siphon all the time,...had to remove the remaining fuel from three different tanks with my present project,...and I do it quite often to fill the lawnmower from one of the cars. CLEAR hose, and stop sucking once you've got the flow visible. Gravity does the rest.
Geeze, check out my free vehicle on my FRANKENTRUCK post! And my leftovers are worth $100/ton when I'm done! Todd.
asphaltburner is offline   Reply With Quote
Old 08-09-2008, 01:15 PM   #12
stump
i scrapped it today.. 350$ 20 minuts of driving, 20 min to load.. worth it to me haha plus the 3/4 tank of fuel in my 87... thanks guys.. i ended up cutting the fuel inlet hose by the tank and had a freind give it a suck haha
