08-10-2008, 12:33 PM | #1 |
surburan windows
any advice on fixing the slideing rear windows.How do you get the glass out of the frames.i have removed the windows and i need to replace the bottom part of the frames rusted out.thanks
08-10-2008, 03:42 PM | #2 |
60-66 Nut
Re: surburan windows
Once you get the frames out of the Suburban, remove as much of the rubber as you can. Then with the window assembly standing upright, put your foot on the bottom channel and pull up on the top channel. It should flex enough to get the glass out. This is what works for me.....
