Old 08-07-2008, 07:19 AM   #1
tylordurben
tylordurben's Avatar
accelorater / gas pedal... w/ V-8
sup everyone, as you know i am putting that 50 GMC back together now. i got most "instruments" hooked up, shifter, steering, brakes. but the gas pedal i am not sure what to do. i need to keep the stock pedal but its designed to "push" the throttle, while now the V-8 SBC requires the throttle to be "pulled".
what are you guys doing to convert the push pedal to a pull pedal???
thanks!
Yaril
tylordurben is offline   Reply With Quote
Old 08-08-2008, 02:50 PM   #2
tylordurben
Re: accelorater / gas pedal... w/ V-8
ok, looked in my friends 53 Bel-air and this is similar to what he has. you push on the pedal then the top arm pulls on the cable...
http://cgi.ebay.com/ebaymotors/1965-....c0.m245.l1318
can somebody help me locate this and a cable?
Old 08-08-2008, 03:38 PM   #3
OrrieG
OrrieG's Avatar
Looks like you found one, 9.99 plus shipping seems to be a good deal considering the cost of gas to go chase one. If you pursue it locally 64-69 Chevelle, LeMans, Skylark, Cutlass should all work, probably big body gm cars too. I also think 74 or so Chevy truck has similar linkage for cable setup too.
Old 08-09-2008, 09:35 PM   #4
solidaxel
solidaxel's Avatar
I woud like to see what a 55-59 chevy truck looks like, any pics ??
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-10-2008, 09:46 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
This is what I used in my 56... Works pretty damn good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-11-2008, 12:08 AM   #6
solidaxel
solidaxel's Avatar
Thanks Frenchblue. I was thinking about the mechanical linkage that is bolted to the firewall.
LS 3 4L70E
