Leaking Injector Pod?
My TBI injector seems to be leaking at idle they both spray the fine mist but one has a small drip that is visible. The only thing is I have tried several injectors and even put in a new one still the same thing a fine mist out of one the other a fine mist and drips. I swapped the injector wires to see if maybe that was it but still the same thing. I have done everything I can think off but replace the pod has anyone seen a the injector pod cause a leak like this.
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
Re: Leaking Injector Pod?
I have found they crack in the area where the O-ring sets.
With the crack the TBI would drip after the engine was shut off. |
| Bookmarks |
