Old 08-11-2008, 08:57 PM   #1
mod58
Unhappy Gas Gauge Problems Help!!!!!!!!!!
Whe the ignition key is in the on postion the gas gauge needle go's to about 3:00 position.Key in off position it falls back to around the full position.I checked everything I could think of,Have resisted power to the sender in the tank and good ground.I changed the gauge and then changed then the whole panel!!!!!!!!!!!! Thanks!!!!!!!!!!!!!
mod58 is offline   Reply With Quote
Old 08-11-2008, 09:48 PM   #2
worthirt_99
worthirt_99's Avatar
Re: Gas Gauge Problems Help!!!!!!!!!!
Do You have a dual tank setup?
worthirt_99 is offline   Reply With Quote
Old 08-11-2008, 10:07 PM   #3
mod58
Yes,It was a doner cab that had duel tanks,but I am only going to run one.I forgot that it was a duel tank cab!!!!!!! What to doooooooooooo????????????
Old 08-11-2008, 10:30 PM   #4
andresco50
andresco50's Avatar
Change the fuel level sender and change all the wiring system! you installed a new fuel gauge????
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-12-2008, 10:00 AM   #5
mod58
I eliminated the cross over switch and the 2nd tank sending unit wire and just have a single wire comming out of the harnes at the fire wall,But the switch wiring is still under the dash.I'n thinking that I will need some kind of jumper wire or I will have to put the switch back in to complete the circut!
Old 08-12-2008, 12:13 PM   #6
andresco50
andresco50's Avatar
Yes maybe you have to install the switch again! search the diagrams in autozone or a repair manual
2001 silverado 2wd
2003 silverado 4wd
Old 08-13-2008, 02:11 AM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
mod58 -
The fuel switch under/on the dash only triggers the fuel valve for a dual tank setup. Aside from switching the fuel delivery from one tank to the other, it also switches the signal wire from the sending units into the single wire (pink?) going to your harness on the firewall. All you may need to is to use a jumper wire between the signal wire (pink?) terminal of the fuel valve connector and the terminal of the wiring (pink/black? or pink/white?) coming from the sending unit. The pic below shows a dual tank setup:
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
