PITbut
Quadrajet question. NEED answer asap....
Anyone know the size of the fuel line nut that goes into the side of the carburetor???? Im thinking its 1/2 or 3/8.
Im doing a fuel line from my mechanical pump to the carb, and i dont know the size on the carb. Carb is not here and just want to get this stuff here so i can just bolt the carb on and attach lines when it shows up.... |
Re: Quadrajet question. NEED answer asap....
the fuel line is 3/8 yet the retaining nut is 5/8 . the filter housing takes a 1 inch wrench , be sure to hold it solid when you loosen the fuel line to avoid twisting the line and its best to have a 5/8 flare or line wrench not to round it off , then its vise grip time . lol
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Active Member
![]() Join Date: Jul 2007
Unless you're in a hurry, I might suggest waiting until you have the carb in hand and do the flairing and fitting then.
However, if you do have a need to do it now, I have a 1977 quadrajet in my garage with the filter and fuel inlet fitting in it. The inside diameter of the female opening where the line from the fuel pump would attach is 1/2 inch. My assumption is that all quadrajets are the same size, but I may be wrong. You could get an adapter if you make one and it doesn't match. Sorry... that's wrong. The 1/2" inside diameter is for the male fitting that goes into the female filter retainer on the side of the carb... Mine just had a short male plug in it. Last edited by 68gmsee; 08-13-2008 at 04:09 PM. |
Built 4 Speed
^ agrees^
Oh when you get to that filter, Your going to want to remove it along with the spring and throw it into your neighbors back yard. get a inline fuel filter.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
#5 | ||
PITbut
thanks for the quick responses. |
Built 4 Speed
its 5/8s i just went out and checked it personally.
the fuel line i could only assume is 3/8 inside diameter. dont got a tape on me but my eye dont usually lie.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 08-13-2008 at 04:22 PM. |
#7 | |
PITbut
AWESOME.... |
PITbut
#9 | |
PITbut
