Old 08-12-2008, 08:19 AM   #1
oteixeira
question on removing front crossmember
OK,
Never done this and I just want to be safe. When you removed the front cross member with everything in place on it, do you need to chain down the springs, or will they stay compressed between the two a-arms? I just want to make sure I don't have to make a trip to the local human repair shop.
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 08-12-2008, 08:31 AM   #2
lost wages
lost wages's Avatar
Re: question on removing front crossmember
springs are in a bucket in the xmember so they wont go anywhere, go ahead yank her out.
lost wages is offline   Reply With Quote
Old 08-12-2008, 08:41 AM   #3
oteixeira
Sweet, I just picked up a 78 Burb member that is in great shape (doesn't even need the brakes re-done) and I just wanna drop it in there. I popped it out of the burb at the outer tie rod ends (where they connect to the spindles) so I am just going to pull the other member hopefully tonight and move forward. I am still waiting on my shipment of por-15 so that is the only thing that may slow me down!
Orlando
Old 08-13-2008, 01:02 AM   #4
lost wages
lost wages's Avatar
you will have to drill a few holes to bolt the new crossmember back in, no big deal, youll see em when you get there.
Old 08-13-2008, 06:35 PM   #5
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
You should grab the rear axle, if you can, and it probably had rallies on it, too.
Mine got the axles, engine, trans, the works out of a 'burb.
68shortstep is offline   Reply With Quote
