Old 08-09-2008, 06:54 PM   #1
8door
Not too old to learn
How best to short drop
My 68 C10 has coils all around. I want to drop it just a little, couple of inches only, mostly to fill in the gap between tires and wheel opening. I want to use same size tires front and rear....maybe:drama
Sorter coils ? or What.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 08-09-2008, 06:55 PM   #2
8door
Re: How best to short drop
Damn wish I could spell sorta coils? Oh ya maybe bags? nope .
SHORTER coils
Old 08-09-2008, 08:14 PM   #3
SCOTI
SCOTI's Avatar
Your front drop options are drop springs, drop spindles (req's disc brakes), stepped a-arms, or cut the stock springs (free & easy). Trimming 1-coil off the stock coils yields a 2-3" drop up front.
For a rear coil suspension, your options are shorter drop (or swap) springs, lowering blocks (up to 2" on the blocks w/15" wheels); or bags. Bags are a good option if you know you're going to work the truck hard & they can be done for about $200 (rear only) if they're manually filled.
Pick the options that suit your plans the best & we can help you w/the specifics.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2008, 08:35 PM   #4
8door
Any disadvantage to cutting a coil out of springs? Dose that affect the compression rate. As in stiffened them up a bit?
Old 08-09-2008, 08:53 PM   #5
SCOTI
SCOTI's Avatar
Yes it increases the spring rate (10-20% is what I've read in magazines but I've never personally verified accurracy).
One coil trimmed has worked on all my vehicles for moderate lowering since the mid 80's so you should be ok. If you don't care for the ride, you're out nothing & can still get drop springs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2008, 02:40 PM   #6
8door
That makes good sense.But looking at the springs particularly on rear, the coil gets smaller at both top and bottom. How do you cut that ???
Old 08-10-2008, 04:13 PM   #7
SCOTI
SCOTI's Avatar
That's why the rears require the different approach. You can't just cut the springs like you can in front.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2008, 05:46 PM   #8
8door
OK SCOTI I went back and reread your initial comment, just didn't get it together sorry.
Anyway I think I'll research the new coils that are dropped. Any sources to consider?
Old 08-10-2008, 07:08 PM   #9
Shane
Shane's Avatar
Guys have used Chevelle / Malibu springs in the rear with mixed results ... some claim 3-4 inches of drop ... some claim no drop ... I have a set of Chevelle springs that I bought to experiment with but got rid of the "test" truck before installing them. I'll let you have them cheap if you're interested.
Shane is offline   Reply With Quote
Old 08-10-2008, 07:44 PM   #10
SCOTI
SCOTI's Avatar
This is the reason I mentioned 'swap' springs. I've heard of more than one guy using Jeep or g-body coils.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2008, 08:09 PM   #11
scotts62
One day...
scotts62's Avatar
Joe231 has a set of jeep springs under his 66, he said it dropped it a bit.
Scott
93 crew cab build
Project 62
Old 08-10-2008, 08:17 PM   #12
joe231
joe231's Avatar
yeah, i got right around 4 inches using the jeep coils and removing the coil over shocks that were on the rear.
here is my thread LINKY
do a search for jeep coils, there are several threads about it
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-14-2008, 04:56 AM   #13
hensonjd
Man it would probably be best to just go to cpp, ece, or somewhere like that and order drop springs. You have to remember all of these others are old springs and it wouldnt hurt to replace them and its not too expencive to do.
hensonjd is offline   Reply With Quote
