Old 08-13-2008, 01:32 PM   #1
Calitruckgrl1
Calitruckgrl1's Avatar
New Wiring Harness
Does anyone have any recommendations on the best place to get a new wiring harness from for my '65? The wiring in my truck is so dilapitated that I'm just going to replace the whole of it.
My 1965 GMC 4x4
http://67-72chevytrucks.com/vboard/s...22#post2754022
My brother's 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
Calitruckgrl1 is offline   Reply With Quote
Old 08-13-2008, 02:26 PM   #2
billydonn
Council of the Elders
billydonn's Avatar
Re: New Wiring Harness
American Autowire's Classic Update kit worked well for me. It gives many extra circuits for power upgrades like AC, power locks, etc. Pretty easy to install...good instructions.... did it myself and I am no electrical expert. Rating= A to A+.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 08-13-2008, 02:30 PM   #3
stretch-t
stretch-t's Avatar
I used a Painless Wiring harness in my street rod. Went in real easy. I'm currently doing a frame off Restro-rod on a '64 GMC SWB, on it I'm planning on using a harness from American Autowire. Comes with all switches and grommet's, but it's pricey.
Good Luck
stretch-t is offline   Reply With Quote
Old 08-13-2008, 04:19 PM   #4
Bazooka
Keepin it old school
Bazooka's Avatar
Good timing on this thread I need the same info and opinions on what harness to use..
Bazooka is offline   Reply With Quote
Old 08-13-2008, 05:02 PM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
If you want to go with "original" type wiring harnesses check out M&H Wire Harness Company. M&H Website Link
I did for most of my harness components. Looking back i should have just went with aftermarket kit. But M&H would definately be an easier install if thats what your looking for.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 08-13-2008, 05:21 PM   #6
62 short step
62 short step's Avatar
I used an E-Z wiring harness. It was about $165, for the price its a decent product. Some don't like it because its cheap, I installed mine 3 years ago and I thinks its a good product.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 08-13-2008, 05:34 PM   #7
NF65Fleetside
NF65Fleetside's Avatar
If you want the original harnesses go through the Truck and Car Shop.... Heres the online catalog and the harnesses are on pages 104-106
http://www.truckandcarshop.com/truck...t60_cover.html
NF65Fleetside is offline   Reply With Quote
Old 08-13-2008, 06:25 PM   #8
LILRED66
LILRED66's Avatar
For factory fit wiring harnesses, try:
www.classicparts.com
www.lmctruck.com
www.bowtiebits.com
www.oldchevytrucks.com
I prefer factory equipment, so I chose to go this route instead of the many aftermarket harnesses available.
LILRED66 is offline   Reply With Quote
Old 08-13-2008, 08:58 PM   #9
joe231
joe231's Avatar
you got any links for the E-Z one?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-13-2008, 09:10 PM   #10
coolair
Another vote for the American Auto Wire Classic Series kit. Very easy to understand - I had never wired a vehicle before and it went very smooth - two years of driving and no problems related to the wiring kit.
coolair is offline   Reply With Quote
Old 08-13-2008, 09:55 PM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
I was thinking about using the Summit harness. It is not a direct fit and will take some doing to install. http://store.summitracing.com/partde...art=SUM-890021 $229 for the 18 circut harness. I am still up in the air about it though.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-13-2008, 09:57 PM   #12
salazar44
65 - Chevy C10
salazar44's Avatar
Adam / Tony,
Pretty sure the factory fit harnesses all come from M&H. The good thing for us So Cal folks is that its local. Ive seen the truck shop ones and there is an M&H card in the baggy.
VIC
Old 08-13-2008, 10:57 PM   #13
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I also used an ez harness, I like it, seems to be pretty good quality and everything is well marked. Thier customer service leave alot to be desired, but a good harness.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 08-13-2008, 11:19 PM   #14
19GMC63
19GMC63's Avatar
I went with a painless harness from summit. I actually liked the fact that it wasn't direct fit. It allowed me to route some of the more visible wires the way I wanted too...hidden and out of the way. The harness is good qualiity, well labeled, and the instruction made sense for the most part. Horn relay is on the fuse block. Comes with a bunch of extra stuff like thick ga. wire and a 50amp maxi fuse for one wire alt. (I put the fuse on the main feed line to protect the whole harness). You can also pull it out along with the coil fuse for security purposes. Even comes with a connector for late model steering columns. Comes with a bunch of extra fuses and connectors too. as all the gromets you need (since it does away with firewall connectors).
I also used painless's wire loom (powerbraid I think?). Cool stuff.
19GMC63 is online now   Reply With Quote
Old 08-14-2008, 07:25 AM   #15
62 short step
Here it is Joe. http://www.ezwiring.com/wiring_harness.html
1965 c-10
86 chevy c/k 20
Old 08-14-2008, 08:59 AM   #16
Darinc74
Darinc74's Avatar
I am planning on using the EZ one also. I found them on E-Bay.
http://cgi.ebay.com/ebaymotors/UNIVE...mZ310074514820
"We the willing led by the unknowing, are doing the impossible for the ungrateful. We have done so much for so long with so little, we are now qualified to do anything with nothing."
Darinc74 is offline   Reply With Quote
