Old 02-11-2003, 08:08 PM   #1
case_bt
case_bt's Avatar
tire lean need advice!!!
after doing my disc convert on my truck the top of my tires lean out
kind of like this \ / is there a way to adjust this I still need to get an alignment but I would like to correct this the best I can on my own for the time being.
Case
case_bt is offline   Reply With Quote
Old 02-11-2003, 08:13 PM   #2
crazy longhorn
Fabricate till you "puke"
Does it look like you have a boatload of shims tween the top a arm's crossshafts & the mounting point on the crossmember?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-11-2003, 09:38 PM   #3
case_bt
case_bt's Avatar
Yes there is and also some washers that are about 1/4" thick would the best thing be to take out all the shims and if that is to much add one at a time
Old 02-11-2003, 09:48 PM   #4
68LSS1
68LSS1's Avatar
Those shims are what is used to adjust camber. That's the tilt you have. Can be / \ or \ /. Pull the washers out as I don't think there should be any there. Just keep in mind even with the tires looking like they are vertical they can still be off enough to cause tire wear. Get it aligned as soon as you can.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 02-11-2003, 10:31 PM   #5
case_bt
case_bt's Avatar
I will next week
The washers are not just normal washers they are rounded on the flats
Old 02-11-2003, 11:30 PM   #6
crazy longhorn
Washers , with a cup on 1 side to fit next to the cross shaft? My longhorn has them. I would try pulling the shims, & get it close so you can get to the alignment shop.....I wouldnt try driving too much till shes realigned tho. good luck....crazyL
Old 02-12-2003, 10:03 AM   #7
case_bt
case_bt's Avatar
thanks for the info
Old 02-12-2003, 10:43 AM   #8
Frank_Zeller
Frank_Zeller's Avatar
Make sure you pull equal amount of shims from the front shaft and rear shaft. This way you lessen the possibility of changing the caster. The shims come in two thicknesses. Leave the washer in.
Here are some links that I found helpfully. You can set the chamber pretty close with a small level. I've been trying to perfect my at home front end alignment skills. Not to hard...just takes time and patients
http://www.familycar.com/alignment.htm#Cam
http://www.allpar.com/fix/alignment.html
http://www.vtr.org/maintain/diy-alignment.html
http://www.quartermax.com/IHRA/Iss05.html
http://www.at-speed.goof.com/writings/alignment
Alignment gages. Would like to get some of these but have not found someone in my area that would like to go in halves with me :0)
http://www.quickcar.net/chassis/ch_cascamga.html
http://www.racerpartswholesale.com/rebco4.htm
http://www.racerpartswholesale.com/smart1.htm
http://www.racerpartswholesale.com/index.html
Frank
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 02-12-2003, 11:56 AM   #9
cbass
cbass's Avatar
n
cbass is offline   Reply With Quote
Old 02-12-2003, 12:39 PM   #10
crazy longhorn
Thats some nice info there Frank!
