Old 08-16-2008, 09:41 AM   #1
bw4sale
bw4sale's Avatar
How are you cleaning parts?
How are you guys cleaning the really grimey parts like suspension? I want to clean and paint my front crossmember and arms while it's apart. I don't have a sand blaster. Wire wheel?
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 08-16-2008, 10:07 AM   #2
eseaton
eseaton's Avatar
Re: How are you cleaning parts?
ive been using the foaming gunk parts cleaner and a pressure washer.
eseaton is offline   Reply With Quote
Old 08-16-2008, 10:09 AM   #3
70GMCer
70GMCer's Avatar
putty knife, wire wheel, brake cleaner or Easy Off oven cleaner (yellow can) always worked for me.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-16-2008, 10:34 AM   #4
Rodms
Rodms's Avatar
Yeah,regular easy off or go to a detail shop and talk them out of some of their degreaser some kind of acid
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-16-2008, 11:33 AM   #5
68_chop_top
68_chop_top's Avatar
Easy Off and a power washer
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 08-16-2008, 12:02 PM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Wire brush, sandpaper, rag.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-16-2008, 12:49 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
scraper first, then oven cleaner, then power washer.
If you don't have a power washer, you can go to the coin op car wash... just clean up after yourself.
Old 08-16-2008, 12:55 PM   #8
mr48chev
mr48chev's Avatar
"Grease Eater" works well to get the oily grease off the parts. Spray it on wait a while and hose or pressure wash it off. Some guys here are using it in their hot tanks to clean engine parts.
Costco usually has a good deal on it. It also works great to clean grease spots off garage floors and driveways and is biodegradable.
Old 08-16-2008, 01:17 PM   #9
RaceAGMC
RaceAGMC's Avatar
I just did my whole front suspension. I used a pressure washer with degreaser. Then i used brake cleaner, rag, putty knife, and a wire brush. If i would do it again, i know for the amount i spent in cleaning chemicals and rags, i could have had my stuff blasted locally. I know a lot of us are on a budget, but it's worth looking into.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 08-16-2008, 03:36 PM   #10
bigblockorange
The oven cleaner is the trick as said before just scrape off the big chuncks first and then let sit out in the weather to remove all the oil residue off the metal. I sent my frame out to the blaster once the thing was cleaned they wouldn't take it with grease on it.
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!!
bigblockorange is offline   Reply With Quote
Old 08-16-2008, 03:45 PM   #11
RaceAGMC
RaceAGMC's Avatar
That's weird, i talked to a guy about soda blasting, he told me i could bring it as is no pre cleaning required.
Old 08-16-2008, 03:47 PM   #12
big_al_71
big_al_71's Avatar
scrapping, wire wheel, degreaser then pressure cleaned!!!!
lots of patience!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-16-2008, 06:21 PM   #13
Ford Assassin
Ford Assassin's Avatar
Super clean, wire wheel, and lots of rags.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-16-2008, 06:23 PM   #14
dragginass
dragginass's Avatar
Hope this doesnt cause an issue....
But heres a good how to that a buddy of mine posted on another forum
http://www.blazinlow.com/forum/showt...t=rust+removal
1971 Chevy C10 LWB Shop Truck
1984 Chevy C30 Dually LWB Tow Pig
1985 Chevy K5 Blazer
dragginass is offline   Reply With Quote
Old 08-16-2008, 10:52 PM   #15
thirdstreettito
Resident of Here
dragginass, that looks really good. Effortless and effective! I still prefer something that takes less than a day.
~Bradley~
Miss having a truck
Old 08-17-2008, 12:35 AM   #16
NWD02
8 to 10 cans of 99 cent store oven degreaser, and a pressure washer. Takes a few applications but it works. May need a scraper in between applications.
NWD02 is offline   Reply With Quote
Old 08-17-2008, 02:01 AM   #17
Longhorn Man
8 to 10 cans of degreaser....
or 3 to 4 cans of oven cleaner...
try it... it works!
Old 08-17-2008, 02:04 AM   #18
72highlander
Sophomore Member
72highlander's Avatar
that NEVER happens, i own two self serve carwashes, and the crap i gotta clean up would make a sailor gag. it's gotten worse since the economy has gone to pot, people don't want to drive to landfill or anywhere else, so it's easiest to go trash the local carwash
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 08-17-2008, 02:21 AM   #19
Longhorn Man
I feel for you. I live in a semi crappy part of town, and the junk I see in the bays at the coin op always surprises me.
Old 08-17-2008, 02:24 AM   #20
72highlander
Sophomore Member
i thought i had just about seen it all, until the other day i see a lady throw some quarters in the fragrance machine and commence to hose herself down with it! i didn't even want to go over and take a look at how bad she was. wow. sorry for the hijack.
Old 08-17-2008, 02:33 AM   #21
AuggieStyle
AuggieStyle's Avatar
if i am gonna strip to metal to paint muratic acid but I DONT RECOMMEND it to others then i will hit it with phosphate of some kind..if i am dealing with rust i use this stuff. http://www.blulightning.com/
AuggieStyle is offline   Reply With Quote
Old 08-17-2008, 08:20 AM   #22
bw4sale
bw4sale's Avatar
Thanks for all the tips. I've used degreaser and a pressure washer but it didn't seem to do enough for me. Maybe I'm impatient. I'll try the oven cleaner.
BRENT
Old 08-17-2008, 08:56 AM   #23
ANTHONY 67
easy off the small parts and press washed i dipping my frame.
ANTHONY 67 is offline   Reply With Quote
