OL BLUU
![]() Join Date: Mar 2004
Hey guys...
I have found a used system here locally... (but haven't purchased it yet). Has anyone installed this on a 350 TBI... any suggestions or inputs on the results will be appreciated! Thanks! Anthony
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
Happy to be here
![]() Join Date: Mar 2000
Re: Airaid Cold Air intake... are they good?
Anthony they work just fine. I had one on a 95 TBI 5.7 Yukon. The only problem is it had a plastic housing that went on the top of the TB. It split open at the seams after a couple years of daily use. It still worked, but did leak a little unfiltered air.
BAD BOW-Silverado XST
OL BLUU
Thanks for the input guys... the guy is asking $140... I will wait for a few days and see.
Thanks again, Anthony
Happy to be here
How much are they new? It's been several years since I bought one, but they were around 180.00 back then.
#6 | |
Georgia Boy
#7 | |
Low & Fast!
Just build one..
Custom Truck Lover!
That price is too high. You can buy a new system for a couple more bucks. Offer him $80 or nothing.
Squarebody guy |
I think some sort of cold air intake would really be beneficial on these trucks, just because when you stop and pop the hood, you can feel the hot air escape and you can feel that all surfaces under the hood, even those far from the engine are hot. I haven't found a way to get fresh air in without doing some surgery.
Of course there is always the cowl hood and air box route, since I need a new hood anyway but it would be nice to get some sort of fresh air setup before then.
1977 GMC Sierra Grande |
Is there anyway to get a fresh air duct to the under side of the bumper without doing any surgery on these trucks ?
I dont know if anyone else has done this, but the stock air intake on my 87 is right on the rad grille support, mounted with a plastic cup lookin thing. Simply remove the hose from the cup, the cup from the support, and put the hose into the hole in the support. Direct air, just make sure u have a filter on top of the motor...i can take some pictures if my shaby description doesnt show u what i mean...lol...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] Last edited by SkylineNXS; 08-15-2008 at 01:24 AM. |
#13 | |
lucky knuckles
![]() Quote:
cool that place is from my old hometown. what was the total cost for your set up? i've got an 82 with the parking light bumper and had been thinking of this since i saw your install. i think i'll pick up some parts next time i'm visiting the hammer. |
#15 |
I was thinking about this the other day, so someone please correct me if I'm a 'tard. If I understand Skyline right, mine's the same way. The hose for my air intake runs right to the grill, off to the side of the radiator so it's not getting any hot air off the cooling system. Isn't this kind of a cold air intake? The air is brought in with out any contamination from the heat of the engine bay or radiator. Well, I mean there's obviously some heating of the air as it flows down the tube on it's way to carburetor land, but you get my drift.
#16 | |
Cruzzzn' Vet
#17 | |
The box is 110 degrees. I went to a smaller serpentine belt system off a Blazer. Blazers and cars don't have the same spacing as trucks from A/C to alternator. I am ordering the black plastic neopreen tubes. The aluminum ducts work but they are easily crushed. They can spark too if they touch the battery. I'm also running a 4" K&N filter. My 4.5 filter would not fit the box. Order a raised base too. A stock base is too low. Carb linkages can get stuck under the base. Installing the air ducts and cutting holes in the radiator support/fender well are hardest procedures. I was inspired by Mike's installation. http://www.73-87.com/7387garage/drivetrain/ram_air.htm I made changes to fit my 91 grill setup. Last edited by gchemist; 08-16-2008 at 04:55 PM. |
