![]() Join Date: Jun 2002
????? Trans Swap???????
To Swap A 700r4 To Replace A Straight Shift What Do I Need. I Have A Auto Column. So,what Do I Need.thanks,buddy
member #16
![]() Join Date: Dec 1999
Re: ????? Trans Swap???????
Well you will need an auto x member, trans oil cooler, Linkage and tv cable setup, and driveline work. Bowtie overdrives should have all the info you need.
http://www.bowtieoverdrives.com/index.shtml
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
sharp as a marble
![]() Join Date: Jan 2007
I just finished this swap. Here is my list
replacement crossmember $100 brake light switch from a early 80's chevy with cruise to make the lock up function properly $15.00 plus some wire and connectors cooler lines $60 Radiator or cooler. I chose the radiator route, Live in Florida, and bought a 4 row radiator for an automatic truck. A/C is next in this truck. To do this you will need different radiator mounts from any of the truck suppliers. $200 or so steering column. I bought a used tilt column for $100. BUT it needed going thru. I sent it to STEERING COLUMNS GALORE $225. new seals for column also tv cable lokar product $65 it is easier to hook up to a Holley or Edelbrock carb. will also need a lokar cable connector at the carb $20.00 I did not like how close the starter was to the exhaust pipes, and bought a mini starter $150.00 you will need a starter regardless, as the OE starter bolts to the bellhousing. I also had my trans guy help me have my 700r4 LOCK UP in third and fourth gear. My truck has a 3.73 rear gear in it, and I love the third gear lock up. It is done with a pressure switch in the valve body. SO how much money did I spend all of the above and $700 rebuilt trans and new converter. plus a $100 core trans I supplied. did the install myself Last edited by cparman; 08-20-2008 at 08:23 PM. |
I would also recomend a radiator because water cools better than air and heat KILLS autos and make sure you set the trans pressures or it won't last. When you get that far do a search and there is a post that I have some info on pressures.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Long Fleet Club
I went through Monster Transmission and got the 700r4 With external lock-up kit and TCI's constant pressure valve body installed. On the transmission part all I had to do was run a power wire for the lock-up kit and set the T/V cable. Without TCI's valve body you have to make sure you set it right or the pressures will be off and you will burn up your transmission.
I would also recommend the radiator for an auto transmission.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 08-21-2008 at 04:12 AM. |
#6 | |
2 or 4 wheel drive?
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
shorten the drive shaft
1997 GMC Sierra Ext 1965 Mustang |
