Old 02-13-2003, 01:03 AM   #3
jeffbo
D.U.F. Member
jeffbo's Avatar
Do you mean that it wouldn't fire, or wouldn't turn over. If it won't even turn over, the first thing to check is your battery and all of the connections because you have no power (or not enough to make it crank). If it wouldn't fire then you either have no fuel or no spark. Pull the gas line of the back of the throttle body and turn the key to the on position. Be ready with a small cup to catch any fuel. If you have fuel flowing, then you have no spark.
MEMBER OF THE DISCS UP FRONT CLUB
'72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt
'68 C-10 4spd (not running)
'79 C-10 LWB Mild 350
'80 Caprice Classic, 2-dr
'97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto
jeffbo is offline   Reply With Quote
