Old 02-09-2001, 07:40 PM   #3
bigd65
bigd65's Avatar
Post
there is a finned type box on the end of your steering column under your dash. actually its under that little square addition at the bottom of the steering column. anyways that little finned box that looks like a very small stereo amp. that is probably bad. that is one of the problems i was having with mine. i found one at a wrecking yard a put it on and now it turns off and on and the delay works,but i still have one problem, my wipers run slow sometimes, i still believe its the box because the one i got from the yard was from a burb that had been totally submerged in salt water. i took it home and cleaned it up and put it on but as i said the wipers run slow sometimes. that im quiet sure is gonna be your problem. let me know, i may need to replace mine with a new one. good luck
85 C10 350/700r4
HOLLEY STREET DOMINATOR IANTAKE
EDELBROCK 1406 COMP. SERIES CARB.
HYPERTECH POWER COIL
FACTORY HEADERS
MAGNAFLOW CAT/MUFFLER/3in. EXHAUST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
and still going
"thats my toy"
Jeff Dodson
Angleton,Tx.
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
