MINE WAS DOING THAT AND I REPLACED THE MOTOR AND STIIL DONE THE SAME, SO IDONT THINK ITS THE THE MOTOR. SURE AM GLAD I KNEW THE GUY AT THE AUTOZONE THEY LET ME RETURN IT AFTER I TRIED IT.
I FOUND ONE OF THOSE BOXES AT A WRECKING YARD AND REPLACED IT BUT IT CAME FROM A BURB THAT HAD BEEN TOTALLY SUBMERGED IN SALT WATER. I TOOK THE BOX HOME AND CLEANED IT UP AND PUT IT ON AND MY WIPERS WORKED BUT WERE SLOW SOMETIMES, BUT IT LET THE DELAY WORK. IM PRETTY SURE I NEED TO REPLACE WITH ANOTHER MAYBE EVEN A NEW ONE BUT THEY ARE EXPENSIVE ALSO. I THINK I WILL CONTINUE TO CHECK WRECKING YARDS. GOOD LUCK LET ME KNOW WHAT IS THE OUT COME IF YOU CHANGE YOURS FIRST, IT PROBABLY IS THE PROBLEM AND NOT THE MOTOR. ------------------ 85 C10 350/700r4 HOLLEY STREET DOMINATOR IANTAKE EDELBROCK 1406 COMP. SERIES CARB. HYPERTECH POWER COIL FACTORY HEADERS MAGNAFLOW CAT/MUFFLER/3in. EXHAUST 3.42 REAR GEARS PROTHANE SUSPENSION-TOTAL KIT and still going "thats my toy" Jeff Dodson Angleton,Tx.
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
| Bookmarks |
