1972 axle swap
Ok so I was at the local pick and pull junkyard today and they have 2 1972 trucks in there both with the rear axles in em. Can I just grab the axle shafts from one and swap them into mine or do I need to grab the whole thing complete.
Re: 1972 axle swap
the 72 axle will be wider and different spline, so yes you need the whole thing
http://www.picturetrail.com/fregon |
SIR
Re: 1972 axle swap
...grab ALL of it!! front suspention too!! and the rear end will bolt right in all you will have to do is trim 1-1/2" out of the lip of the wheel opening if you have a fleetside..concider yourself lucky most everything that year at most yards is GONE!!! so grab what you can... you won't be sorry!
66long low fleet http://community.webshots.com/user/LVNR66 |
Re: 1972 axle swap
we bought both rear axles for $75 a pc. Whats better/different about using the 72 front end parts over the 73-87?
Re: 1972 axle swap
I don't think it's any better but it would be nice to get all your parts off 1 truck.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
Re: 1972 axle swap
Oh and $75 an rearend is a smoking deal.
#7 | |
60-66 Nut
Re: 1972 axle swap
Other than that they're pretty much the same.
