Old 08-28-2008, 11:23 AM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Front Brake Rattle - ARGGGGHHHH!!!
Do you have the brake pad clip on the inside pad?
This should be clipped to the inner pad and then this clip (with pad attached) should fit tightly within the piston on the caliper. This keeps the pad from rattling around.
These spring clips do wear out and loose they "springiness" so you might need to replace them. Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-28-2008, 01:30 PM   #2
jorgensensc
jorgensensc's Avatar
I was going to suggest the same thing. I would venture that these are missing and will solve your problems.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-28-2008, 03:12 PM   #3
Zilverado
Zilverado's Avatar
Shawn
Yes, this is the "retainer clip" I was refering to. I have these, but they are old, and rusty, and quite possibly worn. So my plan now is to replace them with new (to be done tomorrow), and see how things work.
Thanks again.
Zilverado is offline   Reply With Quote
