Old 03-15-2008, 10:41 AM   #26
Infanti
www.infantimachine.com
Infanti's Avatar
Re: Shaved cowl
I agree with shifty.It would have to be contured to the shape of the cowl not just a flat piece of metal.1 piece that you could place over and cover the entire louvers,scribe around then cut the cowl to fit.
Infanti is offline   Reply With Quote
Old 03-16-2008, 01:32 AM   #27
avysittinon22s
avysittinon22s's Avatar
Re: Shaved cowl
A buddy of mine had some type of roller machine that put the curve in it. And it not getto at all!!! It turned out very nice. Its doesnt have much body filler at all. Whats the difference in this and replacing and body patch panel? Custom work takes cutting, welding, and bodyfiller.
avysittinon22s is offline   Reply With Quote
Old 03-16-2008, 02:51 AM   #28
shifty
Questionable
shifty's Avatar
Re: Shaved cowl
It absolutely does - what I'm saying sounds "ghetto", is if you'd taken a flat piece of metal and welded it in with no curve, then used filler to make the curved transitions.
Using filler isn't a bad thing, but the thought of taking something at an angle like this / and smoothing it out to be a curve lik ) using bondo....
Get what I'm saying?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-17-2008, 10:19 PM   #29
class01
class01's Avatar
Re: Shaved cowl
so you gonna make them infanti?
class01 is offline   Reply With Quote
Old 03-18-2008, 02:57 AM   #30
roj2323
Re: Shaved cowl
i wouldn't mind one of these either. i'm tired of cleaning out the crud in my vents so i want to shave them and install vent openings inside the door hinge area. i figure this will avoid the dirt and leaf issue while still provinding a sorce of fresh air for my stock heater setup.
ondrew
roj2323 is offline   Reply With Quote
Old 03-18-2008, 05:51 AM   #31
shifty
Questionable
shifty's Avatar
Re: Shaved cowl
ondrew
I was flipping through the Brothers Truck catalog the other day, and they have firm screens that attach to the underside of the cowl which prevent debris from entering the cowls without shaving the cowl (which kills air flow through the kick vents)
Old 03-21-2008, 09:06 AM   #32
Infanti
Infanti's Avatar
Re: Shaved cowl
class01 just kicking tires at the moment.The largest press i have in the shop is not big enough to make it in 1 piece.The part would be 4' long.What do you guys think if it was in 2 pieces?Also easier to ship.
Old 03-22-2008, 01:31 AM   #33
shifty
Questionable
shifty's Avatar
Re: Shaved cowl
I would be fine with two pieces. I honestly wouldn't feel comfortable cutting out the entire center, I imagine that cutting out the entire 4'+ inside section would render it nearly impossible to weld in the shaved part without warpage and twisting.
Old 03-22-2008, 11:51 PM   #34
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Shaved cowl
agree with shifty. i too would feel good if it was in two pieces....
rodstored-72 is offline   Reply With Quote
Old 03-23-2008, 03:41 AM   #35
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Shaved cowl
Originally Posted by Infanti View Post
For those that don't know,I am the guy on ebay with the shaved panels,thanks for the compliments.How many would be interested in welding in thier own panels for the cowl?
+1 -I'll try anything once... 2 pieces sounds good too.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-27-2008, 09:06 PM   #36
noteron
noteron's Avatar
Re: Shaved cowl
so are you gonna make em?? i could use several sets
noteron is offline   Reply With Quote
Old 08-28-2008, 04:18 PM   #37
Mondo
Mondo's Avatar
Re: Shaved cowl
I know a lot of you want to keep the truck all metal and like the idea of welding something up... but I got this fiberglass cowl that came ready to paint/install and I'm really happy with it.
Contact Tony mgtp001@gmail.com if you want more info (I'm just a satisfied customer, not trying to sell them)
Mondo is offline   Reply With Quote
Old 08-28-2008, 04:32 PM   #38
Ackattack
Ackattack's Avatar
Re: Shaved cowl
man, that looks great!
If it were made out of metal, I think 2 pieces would be best also. I need to keep the wipers too if that matters.
Ackattack is offline   Reply With Quote
Old 08-28-2008, 07:09 PM   #39
Rokcrln
Rokcrln's Avatar
Re: Shaved cowl
I did this one out of 19ga, hand formed it to shape than finished up with a hammer and dolly during and after welding. It was 1pc but 2pc would be easier to handle for the average guy trying this for the first time.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-28-2008, 07:25 PM   #40
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Shaved cowl
where can i send my money??
absolutely want a set, maybe more. I wouldn't want it as one piece though. I'd want individual pieces like mentioned above.
to me it seems that if you were to cut out the existing vent, you'd lose a lot of what little rigidity there is in a cowl, making warping a big problem. since you're more than likely going to have skim coat some filler over the metal work, this loss in rigidity is going to cause cracks.
for me, i've already painted my truck, but would pull the cowl, sand it down, insert these fill plates, paint and reinstall. I got your door, gas and stake plates when i was doing my body work, and they were great. even down to the little tabs on the door locks. if you can produce the same quality and fit, i would absolutely take a set.
IvelDesigns is offline   Reply With Quote
Old 08-28-2008, 08:09 PM   #41
killer71
killer71's Avatar
Re: Shaved cowl
Mondo that is sweet, I love it!!!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
