Old 08-27-2008, 10:57 PM   #1
XXL
Seņor Member
XXL's Avatar
Tie rod thread size/pitch?
Does anyone know the tie rod thread size and pitch (one of them is reverse, of course)? I need to pick up a couple of dies to clean up the threads on mine after I cut them down, but I don't have the truck right now to measure them. Parts are 71+, I believe.
XXL is offline   Reply With Quote
Old 08-29-2008, 09:12 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Tie rod thread size/pitch?
Anyone? Would the manufacturers website list that data?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-29-2008, 09:25 AM   #3
LONGHAIR
You really shouldn't need a die to clean-up the threads. Just thread a nut on the shaft and after you cut and chamfer the end, back the nut off. This should take care of it. Finding a left hand threaded die, for a one-time use? expensive.
Size ...I would guess 5/8"-18
LONGHAIR is offline   Reply With Quote
Old 08-29-2008, 10:23 AM   #4
XXL
Seņor Member
XXL's Avatar
Thanks, guys. I'm going to be cutting them down... and so I wanted the die on there to chase the threads back into place after the cut. A nut will probably do it just fine... which means I need to pick up a nut that will fit (including the reverse thread one)... so the size is still a question I need to resolve. I may have to take a trip to see the truck, pull a tie rod, and just take it to the hardware store. As for price of a couple of dies... I found a 5/8-18 LH online for $15. Cheap enough if I knock off a few 7-11's
Old 08-29-2008, 11:15 AM   #5
LONGHAIR
$15 is not bad, but it is still a "one-time" use thing? Triangle file?
Old 08-30-2008, 10:05 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
If your going to need the nuts anyway, that would be the route I would go. When cutting a threaded shaft, I always jamb a double nut on the shaft, then cut off what I don't need. When your done you have two nuts on the good side to chase the threads with.
But you probably already knew that...
Articles-
"Refining Sierra"
Old 08-30-2008, 01:19 PM   #7
XXL
Seņor Member
XXL's Avatar
It is better to have 2 nuts, yes.
Old 08-30-2008, 06:05 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Preferably jammed together, cause when they are not....
Articles-
"Refining Sierra"
Old 08-31-2008, 08:48 AM   #9
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
On my 79 they where 11/16-18. It wasn't a common size I was trying to find heims for it and nobody had them. Ended up sticking with the tie rods.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
