Its Deja Vu time again
Low Buck Paint Questions
I've decided to literally tear my 65 C10 a part and more or less start replacing the things that need replaced. Now I'm not swimming in cash like I'm sure most of us here are not. If I take a part off say a suspension part off is there a particular paint I should spray it with or can I just brake out a can of Rustoleum flat black and give it a few coats?
My goal is to rid of all surface rust and give the undercarriage a single color opposed to the color of black here, surface rust there mixed with whatever else is living under it. Im not building a show rig, but I'd like to keep the rust away. I figured I could: Remove part Grind off all paint and rust with wire wheel Degrease Prime Spray with spray paint or something of the like. Oil based, Acrylic, Enamel or any other fancy types of paint needed? I thought about using some Por-15 on the frame, but its all up in the air. Im also assuming engine paint would have to be high temp paint since its different. Am I nuts or am I on the right track? Last edited by kizer; 08-29-2008 at 02:55 PM. Reason: Spelling errors |
Re: Low Buck Paint Questions
I would put a coat of POR-15 on everything I wanted to paint, but the engine. Then a coat of Rustoleum, or some enamel would be fine, as PRO-15 can't handle UV rays.
If you paint then everything is in the prep work. I did por 15 on my jeep and it has lasted for a couple years with-out peeling ro flaking - and I didn't put more than 30 hours into the work. I suggest that you buy metal etch though, it seems to make the por15 stick better
I used Tremclad (Rustoleum) flat black on everything under my 72 C10, and rubberized undercoat on all the underside sheetmetal. Where the sun never hits any of that, it lasts really well. For something I was driving, I didn't want to spend huge coin.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Thats what I was thinking. I thought I'd Por-15 the frame and everything else was going to get shot with Rustoluem flat black.
Isn't that rubber coating stuff available in a spray can if needed? I've only been using spray paint, but I know I need to get the spray gun out because its going to get spendy. |
Actually I should look into rolling the Rustoleum because Im sure there is alot wasted on spraying.
I'll have to pick up some and give it a test run. muddpile, thanks for having that build of your 1972 it gave me an idea or two. ![]() Last edited by kizer; 08-29-2008 at 06:23 PM. |
Hot Rod rolled Rustoleum onto a Falcon and made it come out pretty nice. It's a lot of work, but it is cheap.
Here's the article: http://www.hotrod.com/techarticles/b...job/index.html
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
![]() Last edited by MXmaniac; 08-29-2008 at 11:58 PM. |
Cantankerous Geezer
I used to be a big fan of POR-15. After painting the rims for my 52 and following their instructions the paint has failed over the last 10 years.
Someone here got me turned on to rust bullet. Application is easier, it brushes on to a decent finish. www.rustbullet.com
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I mostly rolled my frame and suspension, then brushed and sprayed what A roller couldn't get to. The primer is Tremclad (Rustoleum) regular grey primer. I just used rattle can rubberized undercoating on the underside sheet metal.
I used this stuff on my frame, axles, leafs and other little parts. www.nomorerust.com the ag111 stuff is UV safe but the chassis can isn't (that's what I used with the rust sealer). I put it on with a foam brush and only used 1.5 quarts for two coats. One coat would have worked and this stuff is hard like powdercoat.... $63 for the kit.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-31-2008 at 08:24 PM. |
