Old 09-02-2008, 06:15 PM   #1
abadsvt
abadsvt's Avatar
How to get electrical into the gas tank?
I am stuck and need your help. I am building a gas tank for my truck and I need a way to get the electrical into the gas tank for the fuel pump. I am planning on using a aeromotive a1000 pump sumberged in the tank and can't find any kind of electrical bulkheads or some sort of connector to get the electrical into the tank and sealed so no gas leaks. Any help would be much appreciated. Thanks
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-02-2008, 07:00 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: How to get electrical into the gas tank?
I would recommended getting the factory GM unit (fuel pump, fuel level sender/sump can) and making it fit the tank your building.
Edit: You should still be able to use the pump you have with the GM unit.
Something like this:
http://cgi.ebay.com/ebaymotors/GM-FU...spagenameZWDVW
Hart_Rod is offline   Reply With Quote
Old 09-03-2008, 02:10 AM   #3
TravisH
TravisH's Avatar
Check out Tanks Inc. I think they have something like you're looking for
TravisH is offline   Reply With Quote
Old 09-03-2008, 09:26 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I know sump and submerged pumps use a compression grommet for their cords, but as mentioned I think the original fuel tank sender and connection may be a safer route.
sneakysnake is offline   Reply With Quote
Old 09-03-2008, 11:29 AM   #5
Hart_Rod
Hart_Rod's Avatar
Check out TANKS:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
