Old 09-03-2008, 10:34 AM   #1
7Hotrod1
Power brake conversion question
I bought a new brake booster kit from CPP. The problem I have is that my Edelbrock performer intake has 2 vacuum locations, 1 is going to the transmission and the other goes over to the valve cover. There is a smaller one on the rear of the Edelbrock carb but is a smaller size than the fitting that was supplied with the booster kit. Do you think I can just get a smaller fitting and hose for the booster or do I need to do put a "T" or something in the line that is going to the transmission? I do have this question out to CPP but would like to get this figured out pretty quick. Thanks for any help.
7Hotrod1 is offline   Reply With Quote
Old 09-03-2008, 11:18 AM   #2
Keep on Trucking
Keep on Trucking's Avatar
Re: Power brake conversion question
Do it either way just make sure you are getting manifold vacuum. My preference is a tee or a multi port fitting for the intake.
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach.
Can have new owner for the right price.
"Life is tough, its tougher if you are stupid" (John Wayne)
My buddys truck for sale here.
http://67-72chevytrucks.com/vboard/c...p?product=2676
Keep on Trucking is offline   Reply With Quote
Old 09-03-2008, 04:23 PM   #3
Wrenchbender Ret
The one to the valve cover should be on or close to the carb. It seems the performer carb has a 3/8 vacuum outlet at the rear of the carb. There is a opening in a runner in the manifold in back of the carb. This works good for the power brake & can be t'd with the trans. hose. The trans can be hooked to the carb if there is a 1/4 tube with vacuum at idle.
Wrenchbender Ret is online now   Reply With Quote
Old 09-03-2008, 09:33 PM   #4
7Hotrod1
I got a fitting for the back of the carb and hooked the booster to that. I have good vacuum and believe this will fix my problem. Thanks.
