It'll buff out
Help with heating the coils
I think im going to lower my rear end today by heating the coils.
And I just have a few questions. Do i just heat up the whole coil or just one point on the spring? How much do i need to heat it up? Until its red? And what will happen it its uneven? And just put in any tips you have that i didn't ask about. Sorry I don't know much. |
tryin to get laid
Re: Help with heating the coils
Sorry, my only advice is don't do it
dumb thing to do
The best "help" there is........."Don't do it"
Your safety as well as every other person on the roads are worth the $100 a set of drop springs cost.
Save your money and do it right. |
drop spring $100
cost of repairs when u break a coil when you thought you were being smart and save money aloooooooooot more do it right or dont do it at all too risky and nt worth the trouble. |
we did that to a 72 once all i got to say is listen to the guys above!!!!!!!!!!!!!!!!!
![]() Join Date: Nov 2003
Another vote for don't do it. My old Jimmy had heated coils when I bought it, they rode horribly. They were one of the first things to get replaced.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
It'll buff out
Ok haha thanks i guess i will just save up the money. Also i heard of putting s10 or monte carlo springs will lower it how is the ride quality in those?
Spring steel doesn't take kindly to being heated to yield. They will break sooner or later with the loss of the physical properties in the area that was heated. Don't do it.
here is my thread where i used jeep wrangler coils
http://67-72chevytrucks.com/vboard/s...d.php?t=292466 do a search of jeep coils....should be lots of info
Texas Big Wig
Dang, I cant stand when all these guys bag on heating coils
Heres how you do it... MAY NOT be the BEST way, but does work & I havent had ANY problems from doing it You start at the bottom & start heating it up (till its orange & starting to twist) then you start moving up the coil till you have reached the desired amount of drop I like to park mine one some cement & have a buddy keep a tape measure ran from the ground to the fender well & keep track of how many inches of drop you've done I have done up to 6" but the ride sucks, so 4" or maybe 5" is about the most I would do Oh, & when you lower the first side it will be a lil lower than when you lower the second side (because its not level at that point) Hope you get it done & have no problems just like me & hundreds of other people who have done it for the past 40 years Now, I will go out saying one last thing here Im not saying this is the best thing to do or anything you should do, just another option in the lowering world & if you want to be low & ride good & not worry about springs breaking, then bag your truck Its not much different in price from drop springs & you dont have to have a tank & compressor, just a lil bit of air line & a couple schrader valve will do the job just fine Last edited by Spray-Bomb; 09-02-2008 at 10:00 AM. |
![]() Join Date: Jul 2007
The only reason I would heat a spring is to get an idea of how much drop I wanted to install. (To order my springs). If you do a wanted ad in the parts section for some, somebody just might hook you up. i have some 5'' rear and 2'' front that I'm still not sure I'm going to use. I want to get my wheels/tires first. But somebody I'm sure has some laying around. Don't forget if you go real low you may need to relocate shocks and might need to change your panhard bar. Do it safe or don't do it.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
i have heard of people using jack stands under the frame to "land" the truck at the proper height, then let them cool and remove the stands....i have never done it, just heard some talk of it
#15 |
lowering blocks
1969 Chevy C-10 350/700r4 |
#17 |
You can only lower about 2" with blocks. You start running into another safety issue with more than that.
Yes, I have done the jackstand thing....way back in the day. Part of the reason I wouldn't reccommend doing it. It does not ride well. Those coils are essentially "stacked" like "coil bound" and that leaves a lot less spring to carry the load...it's a lot stiffer. |
#18 |
Texas Big Wig
You can get some Slam Specialties bags from Suicide Doors, for $75 a piece
And you can get some drop springs from CPP for $95 a pair So its about $55 bucks more to go with bags But the cool thing about the bags is, if you ever hook onto a trailer you can just air it up more to keep it level & if you ever decide to bag the front, the rear is already done Its what I would do if I was going to buy something IMO, just heat em, see if you like the height & then buy some bags & put under it ![]() |
#19 |
Happy to be here
![]() Join Date: Mar 2000
Sorry, but just because you have done it doesn't mean it's something that should be recommended. Yes you can heat your coils and get it low cheaply. The possibility of the spring actually breaking is low, but the probability that it will continue to sag is guaranteed.
If you want to cheap out now, be forewarned that your truck will ride like crap and progressively get worse. Anything more than a 3" drop by spring regardless of how it accomplished will net a poor ride. Heating the springs is the fastest way there. You can replace the springs now, or heat them and replace them later.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-03-2008 at 08:41 AM. |
#20 |
#21 |
Not the "best" way to do things, but I have a set of rear Malibu / Chevelle springs that I'm not gonna use ... let me know if you're interested adn we can works something out. cheap too.
#22 |
Prestige Worldwide
![]() Join Date: Feb 2001
#23 |
Hey Spraybomb I was thinking about running bags w/o a tank or compressor until I saved up more money for a drop-member from Poterbuilt. I just didnt think it would work. Where can I buy the schrader valves?
#24 |
Epoxy Primer Friendly
You can get the valves at any OREILLY auto parts, by the tire stuff.
#25 |
Happy to be here
It will work just fine. You can find them on line as well as your local auto parts. If you do the front it will probably work better if your run a separate line/valve for each side. This will prevent air transfer from bag to bag and inhibit body roll.
