09-03-2008, 04:05 PM | #1 |
quick question?(spindles)
I ordered some summit drop spindles for my 86 SWB, b/c of the price, but I should of asked if anybody ever ran into any problem with these? Are they any good? Do they push out your wheel? THAnks..
GROUND ZERO IS R LIMIT |
09-03-2008, 08:20 PM | #2 |
Re: quick question?(spindles)
Can any of the later model guys share anything on the Summit spindles?
Aren't they a name-brand spindle just sold under the summit name? |
09-03-2008, 09:36 PM | #3 |
Someone has got to know about these spindles? I can't be the first person to buy them!!!
09-04-2008, 12:52 PM | #4 |
I was'nt aware summit had their own brand spindles. Only problem they might have is that you can't run a 15" stock wheel on them. My djm 3" spindles are like that.
Mexican |
09-04-2008, 01:37 PM | #5 |
It'd be alot cooler if you did
I believe they are made by "ground force". I've never had a problem with anything bearing the "summit" brand name.
09-04-2008, 03:46 PM | #6 |
Hey thanks guys for the your response,I am currently baggin my truck and will be buying some 22"billets, so I won't have to worry about any rubbing.I will post some pics up soon!!! One more question, where can I get some bag plates for the lower control arms?
09-04-2008, 09:27 PM | #7 |
Happy to be here
You want plates or cups. Most folks run plates on top and cups on bottom.
09-04-2008, 09:59 PM | #9 |
Yes, those are the plates that I'm looking for. I'm just running the plates b/c I got the drop member, so I don't need the tops. Thanks guys
09-04-2008, 10:15 PM | #10 |
67-72 parts collector,…
Make sure you get the correct spindle for the correct size brake rotors on your truck. The 73-87 spindles have two choices available. One is for the early design 1.250" thick brake rotors. The other is for the "light duty" verison,.... which is the 1" thick brake rotor. Make sure you order the correct spindle.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-04-2008 at 10:30 PM. |
09-04-2008, 10:29 PM | #12 |
One day...
There ya go thanks Tim
