Old 09-05-2008, 02:37 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Truck tilt column or Van tilt column?
I am looking at pulling a tilt column that appears to be factory stock. How can I be sure? The wiring harness is the original style horseshoe without an adapter, but can't that be swapped out? The connections under the hood appear to be factory...other than the tranny linkage. There is no SPID label, I already checked. Thanks.
Old 09-05-2008, 04:38 AM   #2
wHATANERD
wHATANERD's Avatar
Re: Truck tilt column or Van tilt column?
I adapted a Van tilt for my truck, to make a van tilt column work in one of our trucks the neutral start/backup light switch would have to me relocated up the column. If the column has not been modified near this switch it probaly a truck column. Also there is a plastic pin in the colapseable shaft that has to be drilled out to shorted that van column about 3 inches so that it will work in the a truck. If the pin is not drilled out it's a truck column. Hope you find this info helpful.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 09-05-2008, 05:03 AM   #3
71 super
71 super's Avatar
truck tilt. the short splined shaft is a good indicator, shaft on vans is about 4/6 inches long. truck about 1.5/2 inches long.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-05-2008, 05:30 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
thats the real deal there.
Old 09-05-2008, 08:50 AM   #5
Putter
More Cowbell....
Putter's Avatar
Truck tilt.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-05-2008, 10:45 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Andy has spoken, and all doubt has been removed. Thanks for the help guys!
Old 09-05-2008, 10:49 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Thanks for your info...the neutral safety switch is in place and working. It does not look to me like it has been modified at all, looks like the factory location
Old 09-05-2008, 04:15 PM   #8
Longhorn Man
dude... I'm not always right.
But it IS a truck unit though.
