Old 02-14-2003, 07:00 PM   #1
72MARIO
72MARIO's Avatar
Wheelies How To & Mods Needed ?
Hey just wondering if anyone here has done a wheelie in a 67-72 . What mods did you do ? Thinking it would be cool if my shorty could do a wheelie
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-14-2003, 07:22 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
I think you'd need some massive amounts of traction, and moreso, move as much weight rearward as possible...or just lighten the front...
You'd be looking at fuel cell in/under the bed, huge slicks, a fiberglass frontend, an aluminum block, heads, and radiator...
Oh, and lots of torque to go with those slicks.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-14-2003, 07:25 PM   #3
72MARIO
72MARIO's Avatar
I got one Slapper Bars
2005 TAHOE DD
Old 02-14-2003, 07:28 PM   #4
jays68yak
jays68yak's Avatar
Have you guys seen monster garage?
You put the motor in the bed backwards running throu a v drive boat setup and back into the rearend.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 02-14-2003, 07:36 PM   #5
69 Short Fleet
Yes,did you see the "Ambulance" that Jesse James and his team built? (rear engine mounted) they couldnt get him out of it he was having way too much fun!!!!! LOL!!
69 Short Fleet is offline   Reply With Quote
Old 02-14-2003, 07:45 PM   #6
mikep
Used to have a truck
mikep's Avatar
Forget about the light front end/ aluminum engine stuff . Thats for real drag racing not plain old wheelstanding. Wheelstands arent that difficult to get out of any vehicle. Theyre not the best way in the world to go fast but if you just want to show off its simple to do. You need a LOT of torque, thin coil front springs with 90/10 shocks and big ( aka huge) meats in back using much stiffer rear springs than you'd typically drag race with . You dontr want to transfer the weight down. You want it to go up. Hell on ET's . Throw some ladder bars in there and 50/50 shocks. Of course you'll twist all over the place without a roll cage and you'll probably get yourself thrown off the track the first time you try it but what the hell.
No truck :-(
mikep is offline   Reply With Quote
Old 02-14-2003, 07:50 PM   #7
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
My opinion, traction,and torque.
I've seen alot of trucks pull the wheels, with a stout motor, a good stall, transbrake, and slicks. the main ingredient in my opinion is to be able to set up the chassis to put the power down.
others may disagree.....a truck is not the easiest thing to make launch hard, but it can be done...good luck.
p.s remeber not to turn the steering wheel while the skinnys are up!!!
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 02-14-2003, 07:54 PM   #8
crazy longhorn
Fabricate till you "puke"
if you want to do wheel stands .....without going broke, rear eng is the ticket! Check out "moving voilation", you will see a dual carbed bug motor......but the pics are old. Shes running a 2.3 turbo Ferd 4 cyl....yes there are scrape marks on the bottom of the back bumper! Here is the link... http://community.webshots.com/user/hotrodhorn F***ing crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-14-2003, 08:11 PM   #9
72MARIO
72MARIO's Avatar
Will 3:73 gears be Ok ? Thinking it would be rad to be able to do wheelies through my town . Not planning on the track stuff so much as just a super cool street truck. How much are ladder bars and are they a easy install?
2005 TAHOE DD
Old 02-14-2003, 08:28 PM   #10
mikep
mikep's Avatar
I hope youve got some big ass meats under there, I'm not talking about scrawny 18 inch rim thin sidewall 35 series tires either. More like 35 inch tall 16 inch wide drag slicks or sticky DOT's on at least 15 X 12 rims. Then your'e going to need to tub the fenderwells. The 3.73's will have to go to at least 4.88's if not 5.13's. And you'd better get a rear end that will handle the shock with some 35 spline axles. You'll probably need a transbrake too and a 5000 or so stall converter.
The laddder bars arent that difficult if you have a welder. About $350 for the bars and a crossmember but you'll need sone cages for the springs so the rear end will rotate and a panhard bar so add about $300.
All in all look at $3000 or so for chassis mods and it will look nothing like it does now.
You have a stout big block ... right.
No truck :-(
Old 02-14-2003, 08:33 PM   #11
72MARIO
72MARIO's Avatar
Nope Just thinking>>>>??????
2005 TAHOE DD
Old 02-14-2003, 08:54 PM   #12
crazy longhorn
Go for it Mario! My old longhorn is too d@mn long to stand up......need some pics that will put a smile on an old man"s face! Stand it up, & show us what a truck is posta do!
Old 02-14-2003, 09:51 PM   #13
Desert Rat
Desert Rat's Avatar
How about some Hydraulics in the front to help get it bouncin' or some big fatties sitting on the tailgate.fill bed with water,have cement truck back up to it and filler up,very nasty blown big block,nitrous,low gears,and big meats,remove front shocks,move motor back,fuel cell and battery in back,fiberglass fenders,hood.just some ideas?
Desert Rat is offline   Reply With Quote
Old 02-14-2003, 09:59 PM   #14
crazy longhorn
DR, do the "fatties" on the back have big tits?
Old 02-14-2003, 10:12 PM   #15
72MARIO
72MARIO's Avatar
Keep it Clean!!! Were not Porn Star's But it looks like CrazyL has a thing for feet he quite the collection !!! :smile:
2005 TAHOE DD
Old 02-14-2003, 11:53 PM   #16
XXL
Seņor Member
XXL's Avatar
Gang, this can be done for free... here's what I did years ago in an old Z28 I had--
Place floorjack under car. Lift car to desired height. Get behind wheel. Have friend snap a photo, making sure that the floor jack is on OTHER side of car and the bottom of it is hidden by the car's shadow. I had people all over town ooh-ing and aah-ing over that pic for quite a while
BTW, the car was no slouch (383 stroker) but it sure as heck couldn't lift the front end up like it looked in the pic).
Kenneth
XXL is offline   Reply With Quote
Old 02-15-2003, 02:46 AM   #17
sano_surfer
ive seen a 71 shorty do it but it was back halfed full cage 653 big block on lots of bottle. 5 somthing gears and 32x15.50r15 mickey thompson e.t drags. so you awnser is yes just need a lot of money oh yeah that truck is street legal
sano_surfer is offline   Reply With Quote
Old 02-15-2003, 10:24 AM   #18
MOTHERTRUCKERS
Check out www.dragtruk.com and Tom Durham jr's 67swb with the wheels in the air.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-15-2003, 12:54 PM   #19
crazy4chevs
crazy4chevs's Avatar
Don't remember where i got it.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 02-15-2003, 01:03 PM   #20
crazy4chevs
pic 2
Old 02-15-2003, 02:13 PM   #21
gangforward
Hootis is as Hootis does...
gangforward's Avatar
This thing ran 9.20's at over 155 mph - amazing what you can do if you put your mind to it.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 02-20-2003, 02:04 AM   #22
pissonNOS
senior member
pissonNOS's Avatar
satambulance was the best monster garage ever
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-20-2003, 04:00 AM   #23
low 84
low 84's Avatar
run FAT slicks, shoot a 300 shot off the line. if you have a motor with 350 ft/lbs at 2000 rpm and you shot a 300 shot at that low rpm you just shot your torque up to about 1,000 ft/lbs . if you hook that up you should get the wheels up. of course you engine would probly explode first along with the rest of your drivetrain unless you built it to withstand that which would take alot of $$$$$$
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
