cab trim
does anybody know how to attach the cab trim for separating the white roof from the lower part of a 2 tone truck. my truck does not have the trim now, but i am thinking about painting the roof white and need to know my options before painting
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
![]() Join Date: Jul 2005
Re: cab trim
It takes the nail head thingys that are part of the cab. A plastic clip with a keyhole disign slides over them then the moulding snaps onto them. You can also by the clips and screw them in.
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 |
Re: cab trim
Does anyone know how to remove the paint divider without damage so it could be reused?
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
Re: cab trim
With patience and care.It`s held by small plastic clips.If you pop the trim on the side,you can slide it off.I use a chisel or putty knife and twist.Just watch closely to see if it`s giving and don`t force.Ask for a picture of where they are located so you have that advantage.
Active Member
![]() Join Date: Jul 2007
Re: cab trim
I'm leaving mine on because I'm thnking of replacing the chrome strip divider on my 68. It really doesn't detract from the looks.
If it was going to be a show type truck, I think it may be possible to simply clip them off with a strong wire/nail cutter and then gently grind them down. I have one or two that broke off and they broke off cleanly and even with the cab... |
![]() Join Date: Mar 2000
Re: cab trim
If you do not originally have the trim on your truck you need
67-72 Cab Rear Paint Divider Screw Stud Set which screws into back of cab metal so that you can then use the 67-72 Cab Rear Paint Divider Clip Set to install the trim. You'll find both on the following page of our web site http://www.gmcpauls.com/trim_clips.htm GMCPaul |
Old member
Re: cab trim
I had mine removed. I painted everything red.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
TOTY 2006
![]() Join Date: Dec 1999
Re: cab trim
My truck did not have the divider trim, and I used #10 screws to attach the plastic trim clips. It was GMCPaul that gave me the measurements of the screw locations. Worked out great...
