Old 09-08-2008, 08:20 AM   #1
subdude
1 or 2 piece driveshaft
will 2 pc. hold up in 84 burb with a 406 w.th400 or should i have 1 pc. made up
subdude is offline   Reply With Quote
Old 09-08-2008, 11:35 PM   #2
Square84
I don't think these pills work
Square84's Avatar
Re: 1 or 2 piece driveshaft
well from my experiance and im sure people will disagree, in high school i had a 3/4 ton 4x4 lifted on 35's with a 383stroker and a turbo 400 with the one peice i kept poppin u joints, when i went to the 2 piece it worked great for as long as i had it.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 09-09-2008, 01:32 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
2 piece is considered to be stronger, just because 2 small shafts with a center support are going to flex less than one huge shaft that has no center support. For example, regular half ton trucks got a 1 piece shaft, but the big 10 or heavy half trucks got a 2 piece.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-09-2008, 02:20 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I think if its getting lifted defiantly a 2 piece but if not I still think it would be better then the one piece but.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
