Old 09-11-2008, 03:48 PM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
can't pump gas
This might not sound like a bad thing but i can't put gas in my truck, whenever i go to put gas in my truck it kind of spits it back out like a juice box that you blow air into that just leaks everything back out at you. Im not sure what it could be. my switch is on the RH tank and it lets me put gas in that one but im not sure if that would have anything to do with it, this has never happened before and i need to put gas in my truck because my gas guage isnt working. if you guys have a way for me to check my guages let me know the only one that is working is my speedo and its off because of my 3.73s.
staggerd86c-10 is offline   Reply With Quote
Old 09-11-2008, 04:18 PM   #2
JCampbell
Re: can't pump gas
I have the same issue. Both my fill and vent lines are rotted bretty badly. I was going to replace them and see if that helped.
Seems to me that if the vent line is rotted/collapsed/otherwise blocked that it would be the most likely culprit.
JCampbell is offline   Reply With Quote
Old 09-11-2008, 04:46 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: can't pump gas
You are probably putting the nozzle to deep in the filler... If it is aimed toward the curved portion it will do that too..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-11-2008, 05:34 PM   #4
watahyahknow
watahyahknow's Avatar
Re: can't pump gas
it might be the filler neck got flattened by some debry flinging onto it from the tire .
you might check inside the rearfender if you can see the fillerneck , you could allso try to get the side you fill the truck over a bit higher by parking it halfway on a curb or sumtin
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-11-2008, 08:08 PM   #5
spr85gmc
spr85gmc's Avatar
Re: can't pump gas
happened to me about 1 hrs from home .. me not knowing wtf was wrong had my truck towed.... pretty much a quick fix cost me 120.00
spr85gmc is offline   Reply With Quote
Old 09-11-2008, 09:22 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: can't pump gas
I had a similiar problem. The tank was FULL!! The switch would not switch tanks.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
