Old 09-08-2008, 08:07 PM   #1
cheford
Pitman arms
I've got a power steering box from a late 70's or early 80 chev pickup 2wd,I'm using a 72 frame and had bought a 67-72 pitman arm. It looks like it should fit but there is still alot of spline showing, is the splined knob larger on the later boxes compared to the earlier ones?
cheford is offline   Reply With Quote
Old 09-09-2008, 09:13 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Pitman arms
Anyone know the answer?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-09-2008, 04:44 PM   #3
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: Pitman arms
This is mine on my 79 Heavy half, hope it helps.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 09-09-2008, 06:45 PM   #4
cheford
Re: Pitman arms
That is about as much spline that is showing on mine, I thought that it should go on farther than that. It appears that it is only half way on the splines. Does anyone else have any input, just wanting to be safe and not sorry later.Thanks 79gmcsierragrande your picture does help.
Old 09-10-2008, 07:01 AM   #5
Turbo85GMC
Turbo85GMC's Avatar
Re: Pitman arms
I took the pitman arm off my '85 C1500 a couple of weeks ago, and it looked like the picture that 79gmcsierragrande posted above. There was about as much of the splines still showing as was covered by the arm. It was on there wicked tight, so it wasn't loose or anything.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 09-10-2008, 06:18 PM   #6
cheford
Re: Pitman arms
Well, that's two of you so far, I'm starting to feel a little more confident. Thanks. I just ordered a Haynes manual and I'm hoping that there will be some good pictures and more info, thanks again
Old 09-16-2008, 06:55 AM   #7
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Pitman arms
I have a '75 PS box ,it also has quite a bit of spline showing
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
