Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-16-2008, 01:26 PM   #1
Super73
Super73's Avatar
Recent pics of my race car.. Not dial up friendly
I was at the shop last night starting to put my truck motor back together. However I did not have a Deep 13mm 12 point for the studs. I also bought the wrong pitch 8mm bolt for the water pump. Right about the time I was getting sad about this, my buddy Joe called and said "When you have some time, come on over so we can figure out where to mount your Turbo" Well, I closed up the shop and got to play on it for a little bit.. Here are some pics I took yesterday.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-16-2008, 01:26 PM   #2
Super73
Super73's Avatar
Re: Recent pics of my race car.. Not dial up friendly
Old 09-16-2008, 01:27 PM   #3
Super73
Super73's Avatar
Old 09-16-2008, 02:21 PM   #4
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
HOLY CRAP!!!! that is VERY VERY GOOD Work
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 09-16-2008, 03:29 PM   #5
57sailplane
57sailplane's Avatar
im wanting to run a turbo also.. on my drag truck. could you give some specs on the set up . turbo size. engine cid and expected engine rpm.. were did you get the innercooler.. oh ya nice work. are you doing it or is this shop doing the work...
57sailplane is offline   Reply With Quote
Old 09-17-2008, 04:19 AM   #6
PA-IndianRider
PA-IndianRider's Avatar
WoW ..... Very nice..... what's the story of that car????
How much "engine setback????
As has been said "very nice work"...... the same is true with this S10 that was at a car show here in Pittsburgh..... someday when I.......
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 09-16-2008, 04:38 PM   #7
djracer
djracer's Avatar
sweet sheet metal work
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-16-2008, 06:10 PM   #8
Super73
Super73's Avatar
I'm leaving the chasis and tin work to my buddy Joe.. He is an artist.. I put the motor together, doing all the wiring, body work ect with a couple buddies..
Turbo is a 91mm F-trim. Motor is a solid roller 347ci LS1 8.5cr with AFR 225 heads. It's built to handle all the boost that turbo can put out (guessing to see 27-28lbs). Planing on spinning it to 8,200 or so..
The intercooler was an off the shelf E-bay deal that Joe reworked with my idea of making it flow through the upper and lower to have more area for cooling. It came with the in and out on top of both end tanks.. Really didn't make sense to me.
Thanks for the compliments.. I'll relay them to Joe as well..
Old 09-17-2008, 12:38 AM   #9
joeys66pickup
Dr. Frankenstein
That thing is going to be makin some serious music at 8200
I Wanna Go Fast!!
Old 11-19-2008, 07:08 PM   #10
Super73
Super73's Avatar
Prostreet, I think the info you were looking for was in post #7
Originally Posted by super73 View Post
turbo is a 91mm f-trim. Motor is a solid roller 347ci ls1 8.5cr with afr 225 heads. It's built to handle all the boost that turbo can put out (guessing to see 27-28lbs). Planing on spinning it to 8,200 or so..
Old 09-17-2008, 12:03 PM   #11
Super73
Super73's Avatar
Honestly, I don't know how far the motor is set back... I set it back once before it going to Joe's I think about 6" and I think he moved it another 4-6" But it's back there..
Car is being built for Silver State Classic. If you get a chance, look it up. Also Laguna Seca is in my back yard.
Old 11-17-2008, 12:38 AM   #12
Super73
Super73's Avatar
Few new pics..
Old 11-18-2008, 02:50 AM   #13
leftcoast66
leftcoast66's Avatar
Love that thing more and more every time I see the pics. Silver State Classic would be fun in that car. Run w/ Big Red...
leftcoast66 is offline   Reply With Quote
Old 11-18-2008, 03:34 PM   #14
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
looks "Good 'n 'Slow!"
LOL, that aughta be a heck of a ride.....what turbo is that and whats the impeller and compressor wheel sizes.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 11-19-2008, 04:19 PM   #15
Super73
Super73's Avatar
Turbo is a PT91. It uses a F0trim 91mm impeller and a T6 compressor with a 1.0x AR..
Thanks guys for the compliments.
Old 11-19-2008, 06:07 PM   #16
joeys66pickup
Dr. Frankenstein
Thats a More Aerodynamic Bodystyle(Has to be by alittle)so Big Red should look out(Blasphmey from my own mouth but its the truth)
I Wanna Go Fast!!
Old 11-19-2008, 06:17 PM   #17
ProStreet83C10
Drag Racer
any idea on what you will be boosting with it?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 11-23-2008, 04:54 PM   #18
ton*loc
ton*loc's Avatar
what exhaust manifolds are those ? what size waste gate are you going to be using ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 11-25-2008, 11:54 AM   #19
Super73
Super73's Avatar
Those are 01+ LS6 Z06 manifolds. I can't remember the size of the WG right how, but I don't remember the size right now.
Old 11-28-2008, 01:34 AM   #20
Outlaw72
Hay Team!!
Outlaw72's Avatar
I really like the looks of that man! Nice work!
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
