Old 09-17-2008, 10:06 PM   #326
huero
1969 Short, Fleet, and Beat
huero's Avatar
Re: project (sweet pea)
Bro, that shade of green look amazing! Good call on the color.
huero is offline   Reply With Quote
Old 09-17-2008, 10:44 PM   #327
5150
C10 Club Tennessee
5150's Avatar
My newborn really takes up my time. Which i am not complaining about that one bit.....She is a joy to have,And Sweet Pea is just a truck.....
Almost makes you not want to go out in the garage, doesn't it?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-18-2008, 09:11 AM   #328
greystoke
That's awesome Tony...congrats on the little sweet pea. I have two daughters myself..both over 20. They are the best part of me without
a doubt.
Dano
greystoke is offline   Reply With Quote
Old 09-18-2008, 10:07 AM   #329
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Congrat's on the Little one, You Have the Right Attitude , Family 1st................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 09-18-2008, 06:55 PM   #330
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Small update.....Was a little slow at work today....Our paint booths have been down for 2 days (Gas Issue)......Anyways....i took my driver side door to work.....Got the lock hole shaved and all the E-coat blocked...Its in ok shape but will need some glaze work.....I got it all ready to wipe in the A.M.....hopefully i will have it in Primer tomorrow ......Then its off for the same treatment to the passengers side......Will Post pics when i get it all done....I have a few now but its cell phone......
bad6772 is offline   Reply With Quote
Old 09-20-2008, 09:31 PM   #331
bad6772
bad6772's Avatar
Well here we go.....First i blocked the whole door (in E-coat) with 80 grit with my long block.....Found a small crown in the door that is not supposed to be there......It probably would never been seen....But it was driving my crazy so after i got the lock cylinder welded up and ground smooth...i wiped the center of the door end to end with glaze.....i would have used some polyfill primer...but i am out so i went this route.after about an hour of blocking from 80 to 180 then to 220 i was ready for some primer.....Name:  lock filler.jpg
Name:  door glazed.jpg
Old 09-20-2008, 09:35 PM   #332
bad6772
bad6772's Avatar
in primer...i still would want to block this primer out with some 180 ....then Re-prime.....And block again when i am ready to spray......Name:  driver door shaved.JPG
Old 09-20-2008, 09:42 PM   #333
bad6772
bad6772's Avatar
One more little update... got the column and steering shaft mocked up....Kinda sucks though i scratched the hell out of the shaft so i will need to spot it back in....i also chipped my upper control arm so i will spot that in also....i do Expect to get chips on these and other pieces .......But when it does its maiden voyage...it will be chip and scratch free....LOL..And for anyone that is doing or has done the tilt conversion.....Does the main steering shaft look to close to the upper control arm....?? The truck is setting on the ground at the moment...And i am pretty sure it wont ever hit.....But it looked close to me......?
Name:  steering shaft.jpg
Old 09-20-2008, 09:56 PM   #334
greystoke
Hey Tony,
I just went out and looked at mine and I would say yours if fine. Mine would fall in the same place as yours.
Dano
Old 09-21-2008, 10:23 PM   #335
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yeah Tony... I just looked at the one ton and the longhorn... same way.
Old 09-22-2008, 06:31 AM   #336
bad6772
bad6772's Avatar
Thanks Man....And thanks Dano
Old 09-27-2008, 08:12 PM   #337
bad6772
bad6772's Avatar
Got the passenger side door lock shaved today and everything glazed up....I am going to go back out in the A.M and give it a blocking and prime....I also picked up a new trans cooler....FOR CHEAP....Went to my local Napa Store and they had one that some one returned ....And they took most if not all of the Mounting Hardware and hoses...SO they could not sell it or return so i got it for $10.00.....Its a heavy duty unit And is $40.00 new so WOOHOO...It will replace my canister style i bought... i just do not think the canister style will be enough......I also bought a pair of the after market headlights (H3) bulbs i think....I got them from a junk yard this A.M for 5 bucks each....They look exactly like the ones i bought for my 67....And those dudes was 80 bucks ....So score again......I will Post some pics up tomorrow ....Name:  plug.JPG
Old 09-27-2008, 11:05 PM   #338
Painter D
Painter D's Avatar
As usual ,looking good.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 09-28-2008, 12:29 PM   #339
my67chevytruck
Under Construction
my67chevytruck's Avatar
Tony,
looking sweet, keep up the awesome work..... Wish i was this far along on our father/son project.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-28-2008, 12:39 PM   #340
bad6772
bad6772's Avatar
Pics of the scores.....I got to get mowing...I got the pas side door in primer....Just need to block both doors again...Re-Edge with the water born and get to the fenders..
.Name:  headlights.JPG
Name:  trans cooler.jpg
Old 09-28-2008, 09:13 PM   #341
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Cool! I replaced my left inner rocker today
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 09-28-2008, 09:57 PM   #342
bad6772
bad6772's Avatar
Slacker
Old 09-29-2008, 01:00 PM   #343
BACKYARD88
BACKYARD88's Avatar
-Mike Owen-
Old 10-04-2008, 09:04 PM   #344
bad6772
bad6772's Avatar
Just so mike dont flame me.....There are no updates.....LOL .....as i am enjoying my newly arrived 1 month old daughter.....Although i do plan to go out in the shop in the am......
Old 10-04-2008, 09:25 PM   #345
joe231
joe231's Avatar
heck yeah man,
cherish every moment, they grow up way too fast
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-05-2008, 08:16 PM   #346
bad6772
bad6772's Avatar
Well i did get a little work done....Got the new trans cooler mounted with some S.S flat bar i had laying around........Looks pretty good....And i think it will function just fine....i also am going to use my old trans cooler as a P.S cooler.....I already drilled the holes in my frame....So i will utilize them.....I will get some pics in the A.M....Its dark outside....
Old 10-05-2008, 10:26 PM   #347
BACKYARD88
BACKYARD88's Avatar
No flaming here, I know what it's like to have a new little one
-Mike Owen-
Old 10-06-2008, 07:21 PM   #348
bad6772
bad6772's Avatar
Aw......Is this OUR moment....lmao
Old 10-07-2008, 05:18 PM   #349
BACKYARD88
BACKYARD88's Avatar
-Mike Owen-
Old 10-07-2008, 09:20 PM   #350
bad6772
bad6772's Avatar
mike i hope missy dont get mad....lol
