![]() Join Date: Jan 2007
Where did this spring go?
I was putting the e-brake assy back in today with all the cables and lines and ended up with this spring that I don't know where it goes. I had put it in a baggie along with other part labeled e-brake stuff. All the other stuff I was able to figure out but not this. Please do not tell me that after putting stuff back togather you did not end up with stuff you couldn't figure where it went. I on the other hand did end up with this and ask your expert advice. Please help...
Hollister Road Co.
Re: Where did this spring go?
it looks like the one that pulls back the release rod
its the spring that pops the pedal back up when you pull the release. you can barely make out the hole in the pic where it goes right after the teeth in the gear. i'm pretty sure i have a 67,68 so i don't have anything to reference. might be wrong
![]() Join Date: Aug 2003
Here ya go.
that particular spring looks to big for the e-brake assy, it looks like the spring to the bench seat adjuster to me
ok i think i got it. was that truck a manual. i think its the spring for the clutch pedal.
No, it is my automatic 1970 chevy blazer! Thanks for your help!
Active Member
![]() Join Date: Dec 2003
It may be the spring that goes on the end of the E-brake cable under the truck. There is a hole at the end of the threaded section that has the adjustment nuts on it. Where the intermediate brake cable is. The spring pulls the E-brake cable back from the e-brake peddle.
Inline 69
if your spring is apprx 6 inches,
possibly brake pedal return spring .... its hard to measure up there jeff ![]() |
#11 | |
Tot Roddin'
What about a seat spring? I had a spring that resembled that on my bench, and I know that you have buckets... just trying to help you figure it out.
And if we only get to see pics one spring at a time, we will be there with you through out this build! ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 09-21-2008 at 12:53 AM. |
