gauges
I picked up a complete set of autometer gauges but the tach and speedo ar smaller than the 5" ones most people use in their projects. Has anyone here used the smaller tach and speedo and if so how did it work out as far as visibility and function?
Re: gauges
they aint worth a crap send them my way ill get rid of them.
Re: gauges
aw man!!! I thought I had a good deal. They will be in your mailbox as soon as you pay for the expensive stamp. LOL.
Chevys Kick A$$
Re: gauges
Yea a couple friends have them and they work fine besides they are a little bit smaller. They are a little bit harder to see though thats for sure.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Manual Transmission Club
![]() Join Date: May 2008
Re: gauges
How much smaller? I'm looking for smaller gauges so I can fit more in on the dash.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
Re: gauges
I have both the ultralite speedometer and tach in the smaller variety. I bought them cause I didn't want to put the tach on the dash like it's some sort of bracket racer. The size is 3 3/8ths. The visibility is fine, but i kind of wish I did spring for autometers optional LED lights in blue. They are something like $13 a piece though, so I didn't. Instead I got the rubber bulb covers.
G to the M to the C......fool! RIP Jerry Reed "The Snowman" |
![]() Join Date: Sep 2008
Re: gauges
I'm am looking at getting the same autometer kit that comes with the 3 3/8ths speedo and tach. My question to everyone, is how do you mount the 3 3/8" gauge in the big 5" hole?
Re: gauges
IM WAnting to put some white after market gauges on my 86. anyone have any pics?.
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
Re: gauges
like i said earlier, i am getting full set of gauges. but the question that i need an answer too, is what ohm does the sending run at when its empty and what ohm when its full. thinking that maybe someone has already tested it or knows. my truck is a 78' gmc sierra grande.
6.0 powered square
Re: gauges
I'm using the ones from orielly's, and there probaly around the same size tach and spedo you ordered, there not to hard to see if a placed the gauges a half inch up they would be perfect
http://www.iequus.com/products.php?c...=100_105&all=1 ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: gauges
heres my dash.....
the fleet..... 57' shortbed stepside 4x4 72' longbed cheyenne super 4x4 78' blazer lil lift w/ chalet 84' shortbed lowrider aka "troubletruck" 84' 1 ton crew cab dually lifted 8" on 38.5 boggers 87' burb shes my daily 89' blazer, wheelin/plow rig 8?' blazer chassised super short stepside |
