BAD BOW-Silverado XST
I'm no 4X4 guru but agree with roland26. Use the foam cell. Since extreme tilting will be exprienced, I would use an electric pump with a manual cut off switch installed too. Your stock fuel lines should work once you modify the ends to fit the electric fuel pump. Block plates for the fuel pump/engine block are realy easy to find.
------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" http://www.geocities.com/abetterchemist/ |
| Bookmarks |
