who makes the tailight gas door???
can any of you guys let me know who makes them(tail light gas door )or the )side markerlight( for relocating your gas tank i want to buy one thanks in advance
Commander Taco Bello
Re: who makes the tailight gas door???
as far as i know, no one makes one. you'll have to build it yourself.
The Older Generation
There is a pretty good thread on the side marker fill in the FAQ forum. Scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". On that page go down to "Sticky: FAQ Index thread" and click on it. When you get into that scroll down to the "Custom Touch" section (almost to the bottom). Also check out the "Custom Gas Filler". I could have just posted a direct link but there is a lot of good info in the FAQ section and now the people that read this thread will know how to get to it. Thanks to Krue for indexing the FAQ's LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-14-2008 at 08:38 AM. |
I never thought of a 56 taillight gas filler thing but was considering a 80s Camaro type filler behind the licence plate .Depending on the bumper I decide to go with.
you do when you fabricate it
Old Skool Club
![]() Join Date: Jun 2001
GM had taillights that swung down to access the gas tank, like the '56 Chevy and mid-50's Cadillacs. The '56-57 Mark II from Lincoln had a taillight that swung to one side as it opened. The '57 Chevy had a section of the rear fin stainless steel that swung open.
Many of the mid-50's FoMoCo cars had the filler behind the license plate, where it mounted above the rear bumper. Later GM cars had them behind the license plate, in the rear bumper. The only problem I would wonder about in the use of a swing-down rear license plate mount would be whether or not you could fill the gas tank if the filler tube was that close to the horizontal plane that mounting the tank and the filler neck would entail.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Tot Roddin'
As mentioned above, it's totally a DIY project...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
someone on here has the tailight gas door,i guess i will fab one or try to
More Cowbell....
Here are some. The second one belongs to member "Yank".
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 09-15-2008 at 09:52 AM. |
Putter,your the man!! i wonder if yank has some detailed pics of how he did this ,the one i saw you pushed the top of the tailight ,and it poped open.thanks alot
Wow ,forget about the license plate thing ( never thought about it being too low to fill),I like the tail light filler now that I've seen it.
Thanks Putter |
Tot Roddin'
If I recall correctly, I think I seen a truck that used a Camaro gas tank and hid the filler behind the license plate.
I have a quick question.... what type of tank did these guys use to have the neck going to the marker light or to the taillight? I know they are not using fuel cells cause they come out of the top so I was thinking blazer tanks. Let it be known please. Thanks.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
ive always use a fuelcellguy (mark) tanks, and the fill tube comes out the side, just above the frame rail
#15 |
i was thinking about this mod and the thought crossed my mind that filler may work better for filling if the hinge was reversed to a swing up verses a swing down.
Trueman |
#16 |
the tank i will use is from a blazer ,i cant wait to get that BOMB out of my truck
#17 |
More Cowbell....
If I recall correctly, Yank used half of a flip-down tag (like the ones found on older Olds/Pontiac/MonteCarlo). Those have a return spring that flipped the tag back up into it's original position. This is how he keeps the tail light closed. (see pic 1 & 2)
Not sure what was used on the teal colored one. If you look closely, it moves completely out of the way. Looks like an actual fuel door hinge like most of use used on our side-marker filler doors.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 09-22-2008 at 08:39 AM. |
#18 |
More Cowbell....
I found a closer photo of the first one.....this is before he cleaned it up....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#19 |
Here's my version.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
#20 |
More Cowbell....
Oh....that's purdy.
What keeps it closed though? Magnets?
#21 |
Thanks Putter. No magnet, but I may add one. There is a spring on the side that holds it closed. When opened, it cams over and holds it open. I have some pics in this thread that explain it a little better.> http://67-72chevytrucks.com/vboard/s...ht=fuel+filler
#22 |
wynne,that is flat out the nicest one i have seen , i might have just came up with an idea for our trade ??
#23 |
here's the link for the 69 Camaro behind the license plate built:
http://67-72chevytrucks.com/vboard/s...d.php?t=243181 This is what I'm most likely going to do to mine.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
#24 | |
