Old 09-14-2008, 12:53 AM   #1
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
How much horsepower do you have?
hey guys, me and my dad are about to do some work on my 79s motor. to get the most out of it that my wallet can handle just wandering how much everyone else is making, and what did u do to get that? thanks
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 09-14-2008, 02:45 AM   #2
74 shortbed 406
Re: How much horsepower do you have?
You need to include more details like heads(aluminum or iron), 2wd or 4wd is a little helpful, pump gas or up to alcohol. Ihad a 355 in a 81 4wd that was around 350-375 hp with 10:1 and aluminum heads on premium. What size you are putting in is also helpful, bbc or sbc??
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 09-14-2008, 10:02 AM   #3
jrsmith_2010
I like turtles...
ok for a 2wd, 350, with or without aluminum heads, cam, pump gas
Old 09-14-2008, 10:57 AM   #4
jrsmith_2010
I like turtles...
doin some lookin, anybody have these heads by summit racing?
http://store.summitracing.com/partde...5&autoview=sku
Old 09-14-2008, 08:17 PM   #5
Albatrossian
Georgia Boy
Albatrossian's Avatar
I'm running a 355 with a set of 2.02 double hump heads, ported and polished, steel crank, LT1 rods, forged flattops running about 10:1. 780cfm QJet, Performer RPM gasket matched, Hedman long tube headers with 1-5/8" primaries to 3" collectors running to Cherry Bomb header mufflers. The cam is .480" lift on 110 degree CL. MSD 6AL box with MSD cap, rotor and coil with Accel wires. I'm guessing it's putting a little over 300 to the tires, probably about 400 at the crank.
Those summit heads are basically the old double hump heads. They're great heads for the price.
Albatrossian is offline   Reply With Quote
Old 09-14-2008, 08:45 PM   #6
jrsmith_2010
I like turtles...
yea they r, but i just noticed that that is for one head, so its 350 per head, idk ive never bought these before, all i know is that i need a 2.02 set of heads. can anyone help?
Old 09-14-2008, 08:50 PM   #7
Albatrossian
Georgia Boy
I'd check your local machine shops and salvage yards.. I'm sure you can get both for a bunch cheaper for $350.
The old saying is, speed is money.. how much do you want to spend?
Old 09-14-2008, 09:02 PM   #8
pilotj
I believe this is a review of those summit heads.
http://67-72chevytrucks.com/vboard/s...d.php?t=286584
1979 Chevy C20 350/TH400
1974 Chevy C30 350/4speed
pilotj is offline   Reply With Quote
Old 09-14-2008, 09:32 PM   #9
jrsmith_2010
I like turtles...
well i have about 800 or so after i get my truck painted, im just findin the best speed for the money
Old 09-14-2008, 09:47 PM   #10
Albatrossian
Georgia Boy
You make all your power in the heads. Run a good exhaust with an x-pipe to get it all out. Buy a good, streetable cam that you don't need a vacuum can to run your brakes off. I'm assuming the truck is going to be a daily driver. With $800, you can buy a master rebuild kit, a good cam and have your heads re-worked(3 angle, clean the bowls up, maybe a good port job) and make a good 300hp. You start getting radical cams and you'll have to start worrying about matching your converter to the cam. A good stall converter will run about $250 or better.
Old 09-14-2008, 11:01 PM   #11
78 Chevyrado
Truck had 165hp 100k miles ago, who knows now.
78 Chevyrado is offline   Reply With Quote
Old 09-15-2008, 04:17 PM   #12
HarrisonTX
310 HP edelbrock "performer" crate motor. (310 at the crank)
It wont get out of its own way.
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 09-15-2008, 04:23 PM   #13
Albatrossian
Georgia Boy
Really? You'd think that it'd be a pretty strong motor.. depending on the trans, it should be putting 210-220 to the ground
Old 09-15-2008, 04:48 PM   #14
swb85
On a budget like Fred Sanford
swb85's Avatar
~450hp/450ft lbs at the flywheel. It gets out of it's own way.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 09-15-2008, 06:01 PM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
355 bone stock ZZ4
More than 355+
355+ for sure with a 750 CFM carb waiting for install in this setup.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 09-15-2008, 06:47 PM   #16
AceX
>130dB Moderator
AceX's Avatar
I'm still working on a plan to extract 400+ from a 350 and still smog it without breaking the bank...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-15-2008, 07:15 PM   #17
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
I think it's time for Turbonium
77 350 Shorty Wide is offline   Reply With Quote
Old 09-15-2008, 07:39 PM   #18
454HO
My carb'd vortec 454 should be making at least 290HP and 410lb-ft torque. It will roast the right side tire all the way through first and well into second if I let it. That is with a stock torque converter and 2.72 gears with a peg leg diff. Tires are 275/60's. I would guess it could run a mid 15 sec 1/4 mile as it is.Will be putting in 3.73 gears and a posi soon I hope.
- Greg
454HO is offline   Reply With Quote
Old 09-22-2008, 08:38 PM   #19
Matt_ks
Matt_ks's Avatar
Well bud, a motor is just a huge vaccume pump, so the more air u can get into the combustion chamber, and the exspell it the more HP u will make, but their is such thing as too big, so here is a idea u could try.. Get your self a set if either Vortec heads or a good set of 202/160 heads. pair it up with a good low to mid range cam say a lunati Bracket master 480 lift or even a 350 horse 327 cam and, then bump the Comp ratio up a bit and im willing to bet that u will see close to 400 or more at the flexplate!
Matt_ks is offline   Reply With Quote
Old 09-22-2008, 10:00 PM   #20
knightlife
Dark Heart Motorsports
knightlife's Avatar
alba... you and I have the same setup!!!!
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 09-22-2008, 10:10 PM   #21
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
My buddy in Michigan runs a bored and whored rear digger S10 and claims to squeeze around 350 HP from a 355 small block with a mild Lunati cam, Vortec heads, and Demon carb. The bottom end is a relatively stock 4 bolt.
I have never dyno’d anything I own nor ever really cared to. Although, the guy that helped tune the Vortec 8.1L I just stuffed into my 78’ K10 claims it should run around 425HP and 480 to 500 LB FT of torque. I doubt I will ever dyno it either but from the seat of the paints feel the custom calibrated non-emissions 8.1L definitely feels a heck of a lot stronger than the 8.1L in my stock 2001 Silverado by far. It does feel pretty quick for a 6800 lb truck even mowing through an old school SM465 transmission. It breaks U-joints and leaf springs real easy now.
DirtyLarry is offline   Reply With Quote
