![]() Join Date: Jun 2007
Lowering Blocks....
Anyone had luck with these? i'm looking to get 2" drop blocks for my rear end to make it set level.
Pros? Cons? thanks in advance. |
Nothing to see here.....
Re: Lowering Blocks....
I made mine from a 2 x 2 x 6.5 inch piece of billet.
I haven't had any ill effects running them. I also run 5 inch drop springs and a CPP Super Trac Bar.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
![]() Join Date: Jan 2008
I made mine out of 2x2 steel tube.They work well,I use stock height springs and shocks.Works for me.
Tasty Cakes!
2x2 steel tube here too.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
I ordered mine from CPP ... they come with all hardware.
its all about the +6 inches
do you have coils, or leafs on that GMC?
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I made mine from 2 1/2" x 2 1/2" heavy wall tubing along with 2" drop springs, works great.
Old member
Just make sure your bolts don't sit lower than your wheel if you have a flat and dig into the road and cause you to have a worse experance than neccesary.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Tasty Cakes!
You could just remove some leafs.
I don't want the rear end to saddle and mess anything up.
lowering blocks are not gonna do you any good ... the leafs are mounted on TOP of the axle if I remember correctly.
Yes my leafs set on top of my axle plus I have square "u" bolts.
Junior Member
You could use longer leaf spring hangers to get about 2".
#15 |
Inline 69
$150.00 Vehicle Applications: 1963 - 1972 Chevrolet C/K Pickup 1963 - 1972 GMC C/K Pickup http://www.zmotive.com/product_info/...ducts_id/2559/ jeff ![]() |
#16 |
i got rear leafs and i just got a drop shackle in the rear
- Josh Im not white trash, I'm one step above that..... more like white clutter |
#17 |
can you flip the axle on top of the leaf(s)? That should get you some drop-
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
#18 | |
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
#19 |
Sounds like drop shackle's are the way to go!
#20 |
Drop shackles are going to be the way I go, i'm just going to make them though.
#21 |
Resident of Here
Get a flip kit.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#22 |
this has already been discussed. please read an entire post before replying.
#23 |
What should the dimensions of my rear shackles for a 2" drop?
