Old 09-24-2008, 02:23 PM   #1
Ackattack
Ackattack's Avatar
front swaybar stands
I'm about to install my front swaybar (1-1/4" ). Do I need to get swaybar stands (I'd probably get the "lowered" stands from ECE). The reason I ask is on my GMC that I had, I bolted the bar directly to the frame (cause I didn't know there even was stands at the time....many years ago). However, on the GMC it worked just fine, so why do I really need the stands?
Ackattack is offline   Reply With Quote
Old 09-24-2008, 03:02 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: front swaybar stands
You can actually install a sway bar without using sway bar brackets, but I think it will depend on how low your truck is. If it's at stock height, then I would use the standard bracket, otherwise lowered brackets/no brackets, would probably put your suspension in a bind.
Since your truck is lowered, I think you would be okay to bolt them directly to the frame and not worry about the brackets. It will pull the bar that much more off the ground... and clearance is a good thing!
Good luck with the install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-24-2008, 04:24 PM   #3
BIG ORANGE
BIG ORANGE's Avatar
I got 2 1/2 drop spindles on our project and I got all the sway bar brackets, should I use the stands also w stock height springs? I do need one of those
1 1/4 bars though seeing I dont have a swaybar itself!!
thanks guys
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 09-24-2008, 05:46 PM   #4
dfosh
I got the kit from ece brackets , bushings ,bolts everything except the bar . I got that at junk yard for about ten bucks . complete set was about 64.00.Truck is 68 gmc everything on the truck is stock i used the lowered brackets.Every thing worked great about an hour to install.
dfosh is offline   Reply With Quote
Old 09-24-2008, 08:12 PM   #5
SCOTI
SCOTI's Avatar
No drop = stock height 'stands'.
Mild drop (2-4") = shorter aftermarket stands.
Extreme drop (6+") bolt it directly to the frame.
Each one of these scenarios should keep the bar level w/the frame @ ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-25-2008, 02:39 AM   #6
Brad
Out of the carpool lane.
Brad's Avatar
IIRC for a mild drop you can flip the bar upside-down and bolt it to the frame. I seem to recall having done this on my '67 many years ago.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-25-2008, 06:46 AM   #7
larry may
Here is a process created by a board member with pictures. Found in FAQ
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 09-25-2008, 08:15 AM   #8
SCOTI
SCOTI's Avatar
I've seen guys install the bar on the inside of original brackets on mild drops vs. purchasing new shorter brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-25-2008, 02:14 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... now there's an idea I never thought about.
-Nate
Old 09-25-2008, 02:21 PM   #10
cameeks
Long Fleet Club
cameeks's Avatar
That is right if the drop is with coils. Drop spindles should have the sway bar mount at the stock location right?
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 09-25-2008, 02:58 PM   #11
SCOTI
SCOTI's Avatar
4" drops would be spindles & springs (or bags) & would be where I would start considering the use of the shorter stands (or reversing the mounting position using the stock stands).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
