Old 08-25-2008, 03:49 PM   #251
68 short step
Re: project INCREDIBLE HULK 6.2L with 6L80E
nope....better
68 short step is offline   Reply With Quote
Old 09-21-2008, 08:47 PM   #252
68 short step
ok, getting this thread back to the top.......the vettes dash was gonna be modded to fit this dash, but after looking at it and measureing the curved peices look good on the vette dash cause its small.....put the same curved peices on a truck dash, and they look small.....so keeping with that look im gonna make my own dash outta metal......so after cutting the dash appart, i welded in a filler peice for the whole dash, then bent up some tube stock round bar......to get the skelaton on the dash.....
Old 09-22-2008, 12:03 AM   #253
SCOTI
SCOTI's Avatar
Would a 61-63 GM truck dash not work for your goal? Seems it would be an easier fabrication.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-22-2008, 01:08 AM   #254
tdave00
Restoring a 68 SWB
tdave00's Avatar
I always look forward to the updates on this build. Cool mods going on!
tdave00 is offline   Reply With Quote
Old 09-23-2008, 11:31 PM   #255
68 short step
yea, easier, but not quite what we want to do.....
Old 09-25-2008, 08:15 PM   #256
Painter D
Painter D's Avatar
Quality work being done here. Keep it up.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 09-28-2008, 02:29 PM   #257
68 short step
got some loose ends wraped up, completed the capped wire gutter, and also started to shave the drip rail.....
Old 09-28-2008, 04:03 PM   #258
71Hulk
After looking at the picts i don't think we need the round stock...
looks sweet to me!
71Hulk is offline   Reply With Quote
Old 10-25-2008, 10:55 PM   #259
bowtieboy93
bowtieboy93's Avatar
anything new?
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 10-25-2008, 11:23 PM   #260
68 short step
little bit of progress......working on the dash still here are a few pics, they are a bit dark, but you get the idea.....
i bent the hoop on the end of the center console, then braced the center section, rough cut a peice of metal for the center, and worked myself around useing clekos to hold everything in place......i then plug welded everything, and cut to shape.....ill get some better pics of everything up tomorrow
Old 10-26-2008, 09:27 PM   #261
68 short step
here are some more dash progress pics..
made a templet out of cardboard, transfer it to metal, rough cut it out, trimed it a bit, then clekoed it in place.......and the same for the pass. side.....here are the pics
Old 10-26-2008, 09:28 PM   #262
68 short step
Old 10-26-2008, 09:32 PM   #263
msgross
msgross's Avatar
very interesting concept... are the window defrost holes not centered on the original dashes? Are you gonna fill them in too?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-26-2008, 09:51 PM   #264
68 short step
not sure bout the defrost vents being sysmetrical, but they will be filled in and smoothed.....if you look carefully in the center of the dash i have a center line (in red) for my reffrence...
Old 10-26-2008, 10:26 PM   #265
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Looking nice.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 10-26-2008, 10:39 PM   #266
nuke1
nuke1's Avatar
that is gonna look amazing
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-27-2008, 01:55 AM   #267
tdave00
Restoring a 68 SWB
tdave00's Avatar
Pretty fancy looking. I wanna see more.
Old 10-27-2008, 03:34 AM   #268
Frizzle Fry
Frizzle Fry's Avatar
That is bada$$ That's what I had in mind for my 61.
Frizzle Fry is offline   Reply With Quote
Old 10-27-2008, 10:54 PM   #269
Painter D
Painter D's Avatar
x2
Old 10-28-2008, 12:53 AM   #270
bowtieboy93
Looks great!
Travis
Old 11-02-2008, 10:00 PM   #271
68 short step
got the steering column in, its a ididit tilt, column shift, chrome, one... the mounting positon had to be slighly moved over, do to the underdashed brake setup... to do away with the bungy cord, the upper part of the column mounting bracket was made from a portion of exhaust tubeing..... here is the pics...
Old 11-02-2008, 10:13 PM   #272
babyblueoval
babyblueoval's Avatar
Ooooh.....It's soooo shiny.......
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 11-03-2008, 10:34 AM   #273
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have a question about the mount on the fire wall side of the column. Where did ya get it and can it be used on a regular stock column?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-03-2008, 07:32 PM   #274
68 short step
i got it from summit racing....they are called a steering column bulkhead, the one i got is 2.25" round... but you can get them in 2" diamater too (stock column OD size).
Old 11-03-2008, 07:35 PM   #275
Painter D
Painter D's Avatar
Looks like it's coming along nicely.
I'm diggin the dash too.
