Old 02-17-2003, 03:34 PM   #1
KEH
Better late than never
KEH's Avatar
Motor mounts
I can't remember what bolt is used to attach the mount to the tower. Also, is it just a bolt & washer, or is there another rubber piece that I should be looking as well.
Sure wish I would've been more organized 10 yrs ago when I stripped the truck apart.
Thanks for your help.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 02-17-2003, 03:54 PM   #2
crazy longhorn
Fabricate till you "puke"
If its an I 6 , or a sb it has a 7/16-14 NC bolt approx 1 " long with a lock washer,& a large flatwasher......no other parts on the bottom. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-17-2003, 05:12 PM   #3
KEH
KEH's Avatar
Thanks crazyl, I appreciate the reply. After a long, 10 yrs, the engine is going in.
Old 02-17-2003, 05:26 PM   #4
crazy longhorn
I have had my longhorn for 18 yrs, the first 8 or 9 yrs it was pcs......I do understand about a long term project! dont priorities"bite"? good luck with the project....crazyL
