Old 09-28-2008, 07:06 PM   #1
drivethechevy
drivethechevy's Avatar
transmission id
my 68 k10 came with 2 granny gear 4 speed trannys, one is instaled in the truck and matted to my rockwell 221 where it will stay so i wanna know what my tranny is, the installed tranny has the standard shift patern 1234r, here are a couple pics of it
im thinking the second tranny that was in the bed of the truck is an older gm tranny but i may be wrong, the patern is r1234 which is different then the ones im used to and it doesnt look like it can be mated to a t-case
so im guessing a 2 wheel drive, here are a couple pics of its casting numbers
thanks alot guys
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 09-28-2008, 08:04 PM   #2
BobS
BobS's Avatar
Re: transmission id
Nate,
The one in your truck is a SM-465, the other one is a SM-420, it was used in GM trucks through 67.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 09-28-2008, 08:12 PM   #3
justcuz
justcuz's Avatar
Re: transmission id
Not sure but I think the 420 has a lower granny. Reverse is were on each trans? I thought the 420 was left and back, I have one in the garage, just too lazy to go look! Does the 465 have an aluminum top cover? when did they stop using that transmission?
justcuz is offline   Reply With Quote
Old 09-28-2008, 08:13 PM   #4
drivethechevy
Re: transmission id
thanks bob
what are the ups and downs of both trannys?
was the sm-465 used in 2wheel drives?
what trannys might have been used in a 70 gmc 2 wheel, sry no pictures of this one
Old 09-28-2008, 08:19 PM   #5
drivethechevy
Re: transmission id
reverse on the 420 is left and down, on the 465 it is right and down, it looked cast when i was out messing with my truck earlier, but its caked in grease and paint, its possible that its aluminum though
Old 09-28-2008, 08:31 PM   #6
BobS
BobS's Avatar
Re: transmission id
The SM-420 does have a lower first gear and it's shorter, not really advantages in our trucks but it makes a big difference to the rock crawling crowd. The 465 is a lot easier to find parts for, they were used up into the late 80s or early 90s, not sure exactly when they went away. They were used in both 2WD and 4X4s. The transmission with the aluminum cover is the NP (New Process) -435, they were only used in 2WDs, mostly camper specials and the like.
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 09-28-2008, 08:31 PM   #7
justcuz
justcuz's Avatar
Re: transmission id
Thats what I remembered on the 420. Both are great transmissions with the 420 being a little noisier (older style transmission).
Old 09-28-2008, 08:34 PM   #8
drivethechevy
Re: transmission id
thanks alot for the info
nate
Old 09-28-2008, 08:36 PM   #9
justcuz
justcuz's Avatar
Re: transmission id
Bob
And the NP 435 were used in Fords and Dodges too. The 420 is popular with the Jeep guys, you can run the 420 with Dana 18 gears in a Dana 20 t-case and make a real crawler out of a Jeep. Popular in the late 60's early 70's behind the little Buick V6.
Old 09-28-2008, 09:39 PM   #10
chevy29267truck
Re: transmission id
nice transmission nate i have a four speed in 67 chevy 3/4 ton long wheel base truck how many diffent four speed trannys where put in the 1967-1972 chevy trucks one other thing dont lose or let any one take your four speed shifer,rod if it happent north west transmission from OH has them for $100 with the parts that go on the end of the shifter,rod
chevy29267truck is offline   Reply With Quote
Old 09-28-2008, 10:11 PM   #11
chevy29267truck
Re: transmission id
what four speed transmission is this
1 3
n
2 r
Old 09-28-2008, 10:14 PM   #12
chevy29267truck
Re: transmission id
i mean the one 1 than2 3 n 4 r
Old 09-28-2008, 10:19 PM   #13
drivethechevy
Re: transmission id
thanks for that info, ive got a spare 465 so i should be fine, and the 420 probly wont be around to much longer
all i know about trannys that came in these trucks is from this thread, but that sounds like a standard manual shift patern
