Old 09-29-2008, 12:28 AM   #1
sixtyfour
Zombie Killer
sixtyfour's Avatar
Can you identify this wheel?
This is the spare off my truck, it's different then the stock wheels on my 64. The back spacing is 3 1/2" which is about a 1/4" less then the original wheels. I did a disc brake conversion this weekend the the original wheels won't work but my spare works great! So I need to find more of these to run.
Some of the special markings are "K186 15 XX". I couldn't find any other part numbers??? I forgot to get a full front shot but it looks just like the originals.
Click pics for bigger images.
Thanks for any help....
1964 C10 Long Step
sixtyfour is offline   Reply With Quote
Old 09-29-2008, 02:39 PM   #2
sixtyfour
Zombie Killer
sixtyfour's Avatar
Re: Can you identify this wheel?
anyone????? Any ideas...
1964 C10 Long Step
Old 09-29-2008, 03:24 PM   #3
TimE
Hey Y'all!!
TimE's Avatar
I have no idea about the stampings but my guess would be that it is a later model rim. Hopefully someone more knowledgeable will chime in soon.
TimE is offline   Reply With Quote
Old 09-29-2008, 04:47 PM   #4
muscletrucks
muscletrucks's Avatar
I did a little looking around the internet to see what I could find. There appears to be nothing significate about the rim except it is a rim rated for trailers (DOT-T)
I hope this helps.
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 09-29-2008, 08:07 PM   #5
sixtyfour
Zombie Killer
sixtyfour's Avatar
I've found where the issue is between the stock and the spare wheels is. On the stockers they have an inside diameter of 12", on the spare I have it has an inside diameter of 13". So if anyone has a line on some steel wheels 6 lug 15x6 w/inner diameter of 13" or more let me know. I'm having trouble finding anything.
Mike
1964 C10 Long Step
Old 09-30-2008, 09:34 PM   #6
2manyprojects
2manyprojects's Avatar
The spare might be a 4X4 wheel. Try one for a 71 up they had disc and 6 lugs, so I'm guessing it would probably work.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
