09-26-2008, 12:55 AM | #1 |
86 C10
fuel cells?
What would be better plastic or aluminum?
I just need something to get rid of original tank inside bed. I'm leaning towards the plastic since its more in my budget just wanted to see if it would be good enough?
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
09-26-2008, 01:20 AM | #2 |
It'd be alot cooler if you did
Re: fuel cells?
I would stick it out and get a stainless or aluminum one.
09-26-2008, 01:27 AM | #3 |
Re: fuel cells?
i just got a plastic it looks great!!! since you're on a budget you mine as well!
09-26-2008, 03:32 AM | #4 |
Re: fuel cells?
09-26-2008, 08:51 AM | #5 |
Re: fuel cells?
Summit sells some nice aluminum ones and they are not too expensive. Plus you can get them natural or in a couple of different colors -you could always polish one if you wanted to go fancy. My vote is for an aluminum one!
09-26-2008, 10:42 AM | #6 |
Re: fuel cells?
I am also planning on a fuel cell in my 79 k35. Plastic or aluminum will work for me but have a slightly different question.
Is there any problem with state inspections for fuel cells. I am in New Jersey and them do emission inspections before I install a fuel cell just wondering if anyone had any problems with inspections Thanks Ed |
09-28-2008, 10:43 PM | #7 |
86 C10
Re: fuel cells?
so there is really nothing bad about the plastic but it will be better if i get an aluminum one right
09-28-2008, 11:17 PM | #8 |
Building Dreams out of Dimes!
Re: fuel cells?
I too have the same questions about the fuels cells. Any recomendations on what size would fit best for a shortbed?
09-29-2008, 01:35 AM | #9 |
78 Big10 454
Re: fuel cells?
May I suggest that you contact Transfer Flow, Inc. in Chico, CA. They make outstanding fuel tanks. My Big 10 came with one factory 16.5 gallon saddle tank. With a 454, that didn't get me very far before I was riding on fumes. I opted for a 26.5 gallon tank that uses the factory fill and sits between the frame in place of the spare tire. That has been a blessing!
09-29-2008, 08:04 AM | #10 |
yeller
Re: fuel cells?
I am running a 16 gallon 'cell underneath my bed...same size tank as the stock one the truck came with.
http://www.73-87.com/7387garage/chas...ellinstall.htm If I could do it all over again, and money was no object, I might use an aluminum one. But to be honest, since this 'cell is underneath the bed, I am very happy with it and don't plan to change it out. The problem with plastic fuel cells is they need to be mounted so they are not exposed to direct sunlight/heat. If hey are simply bolted to the top of the bed, they will warp and look like crap over time.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 09-29-2008 at 08:05 AM. |
09-29-2008, 01:21 PM | #11 |
Re: fuel cells?
Go for the aluminum!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
09-29-2008, 01:31 PM | #12 |
Re: fuel cells?
I would be worried that the plastic would warp because to the expanding and contracting of gas.
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
09-29-2008, 02:03 PM | #13 |
86 C10
Re: fuel cells?
so what about this one
heres summits part number-SUM-293220-S I think its good for the price but what do y'all think about it?
09-29-2008, 03:18 PM | #14 |
yeller
Re: fuel cells?
I don't think that will cause it, it usually the heat and direct exposure to sunlight that causes them to warp.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-29-2008, 03:21 PM | #15 |
Re: fuel cells?
That looks like a good tank. Comes with a 90 ohm sending unit and it is plumbed for AN fittings. With the dimensions being only 24" x 20", there will probably be no frame mods necessary.
09-29-2008, 03:24 PM | #16 |
Re: fuel cells?
Here in the great state of Kansas, a law was passed sometime ago banning the filling of plastic gas cans at the gas stations. Is that censorship? HAHA
