Re: Points vs HEI 1969 C/10
That could be why she's stuttering a little when I get on it. It comes out of it though, kind of weired. It's like it a gear or shift within the distb. or something. When it does ger to the point, it kicks into another gear and goes. Happens very early, but does catch up enough to get a good. Could be a carb adjustment too. I did not change anything there. I would think you almost have to right? It fired righ up and held an idle so I did not touch anything.
One more thing I forgot to mention, I was reading up on the recommended gap for the plugs when doing this swap on the site and what seemed to be the consensus .035 or .45 on the gap. Mine were again not touched at .35. Should I open them up. Seems like the Quad is a little late opening up now too. The timing was not set by timing light. I'm kinf of just mentioning things thing is case someone can help diagnose.
