Strong Arm LCA ball joints
Does anyone know what kind of ball joint the lower C.A takes? I Emailed ART weeks ago about ordering one but never heard back from them. can i just buy one at the local parts store??
Re: Strong Arm LCA ball joints
I have used replacement ball joints through Moog and also Carquest.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Do you have an application or a part number?
I have used "factory replacement" parts. The application will be determined by the spindles one's running. The lower ball joints for the 1/2 ton from 63-87 have the same diameter sleeve and will press into the Strong Arms. I do know there is a "problem solver" ball joint offered by Moog that is a tiny bit larger in diameter, made to press into worn factory arms.... those would not be necesary for the Strong Arms. I can always get you a carquest part number if necessary.
#5 | |
I didn't realize the ART arms took the same OEM ball joint as the stock arms. Thanks.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-29-2008 at 09:00 PM. |
I believe the lower 1/2 ton ball joints will either be 63-70, 71-72, or 73-87. What year spindles/truck are you working with?
#8 | |
Not only are the balljont factory replacements on the ART arms, so are the bushings (all Strong Arm bushings are the 73-87 rubber style). The Strong Arms are a great product and well designed.
Why not give them a call?
![]() Right on their home page ... I would guess they would know exactly what you need. |
#10 | ||
Jon@AirRideTech
give me a call and I'll take care of you we use moog factory replacement ball joints my dirrect line is 812 481 4710
Selling The best Damn Air Suspension www.ridetech.com jon@ridetech.com (812) 482-2932 |
Thanks for the help on this. I really appreciate it!!
Sounds like Jon may have answered your questions, but the 2006 spindles will not be compatible with the C-10 suspension/steering components. You might be able to make them fit somehow, but the spindle's geometry is not the same.
